Old 10-17-2012, 05:38 PM   #1
falcon-N-Air's Avatar
1995 34' Excella
Dalton , Georgia
Not wanting to sweat it in Georgia!
I am needing some info on mounting a roof top A/C on a 1968 Safari. The wiring Diagram shows an A/C circuit going to the middle vent, but no wire appears to be there. Just curious if any one else has crossed this Bridge before and could help shed some light on the subject.
Kindest Regards,
Eric
falcon-N-Air is offline   Reply With Quote
Old 10-17-2012, 06:05 PM   #2
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I converted my from an Armstrong unit to the newer type dometic. It required cutting a hole in the roof, and inside ceiling. I framed it in with cut down 2x4s. I did it ended up being right next to a rib, so real strong. I think the hardest part will be running your power lead. If you want it hidden you might have to snake it behind the inside wall. You will most likely need separate set of breakers running off you main power box. I know there is a couple of good threads showing the job.
Silverflames is offline   Reply With Quote
Old 10-18-2012, 04:31 AM   #3
1995 34' Excella
Dalton , Georgia
Thank you very much Keith for the helpful information, I will see if I can find the threads with the installation.
Regards,
Eric
