Old 06-14-2015, 01:16 PM   #29
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, try a solar hair dryer; Sit outside for thirty minutes. [works for me]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-15-2015, 07:54 AM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by kamadeca View Post
Hi there,
If you are getting a new Airstream it might not come with a 12V plug. Our 2015 30' Serenity does not have any 12 v plugs. You might want to check with your dealer, and if it doesn't consider having one installed
I thought all RVs had the 12 volt plug in the same plate as the television antenna signal strength amplifier. In addition to that one, our trailer has one in the locker with the stereo and Blu-ray player.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-15-2015, 08:09 AM   #31
mefly2's Avatar
2015 25' FB Eddie Bauer
USBs, but no direct 12v on our 2015 ... read and learn. Not all models and years are specified with the same equipment.
Old 06-15-2015, 08:56 AM   #32
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
If one looks on the back side of the USB plugs, they are fed by 12v DC through what looks like AWG 12 or 14 wire. A check in your fuse panel can determine the circuit's capacity.
But, as has been stated, one needs to be running the generator for 10 plus Amps of 110v AC power which is what a useful hairdryer requires. Or, my espresso machine.... Espresso can be consumed while my hair drys☕️
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 06-15-2015, 09:32 AM   #33
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have experience with 12 volt appliances, coffee pots, hair dryers, etc. from working around boats. They are absolute power hogs, something to keep in mind.
MICHAEL
Old 06-15-2015, 05:58 PM   #34
m.hony's Avatar
2013 30' Classic
Not even with the TV antenna signal strength amplifier? Wow-
TAC #MS-10
Airforums #70955
Old 06-18-2015, 10:37 PM   #35
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I like Paula's solution of using micro fiber towels for drying hair.
We have a small travel hair dryer that has two heat settings. On low it uses about 400 watts; on high it uses 1,600 watts. We can run it on low using our 1,000 watt Honda genny.
Recently I learned that my wife now dries her hair using the cool air setting to keep from burning her hair. Her big hair dryer has two fan settings. On low it uses about 90 watts; on high is uses about 160 watts. I could easily use our 400 watt inverter to operate her hair dryer on the fan only setting.
I believe using the micro fiber towels and the hair dryer on the fan only setting would be a good way to dry my wife's hair when relying only on 12v power from the batteries.
Dan
Old 06-20-2015, 06:32 AM   #36
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
My boot camp haircut sure made hair care easy - the style choices were peach or que ball.
Old 06-20-2015, 06:54 AM   #37
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I actually had enough hair in my teens that I needed a blow dryer. These days, the fluttering of a moth above my head dries my "hair" right quick! 😄
SteveSueMac is online now   Reply With Quote
Old 06-20-2015, 07:46 AM   #38
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Hooah!!!
>>ron<<
U.S. Army (Ret)
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
I'm not a smart man, Jenny... but I know what oxidation/corrosion is. Taylormade Cleaning, Stripping & Polishing 4 11-19-2013 09:43 PM
Disney's "I ARE SMART" Airstream! fotochop On The Road... 8 01-06-2008 09:21 AM
I are smart Silvertwinkie On The Road... 8 05-06-2007 08:23 AM
A smart way to avoid flood damage HHP Off Topic Forum 16 07-24-2006 08:41 AM
Would it be smart to pour a pad? 26.982 amu Axles 17 07-19-2006 08:24 PM
