Old 10-08-2011, 10:57 AM   #1
kathyek's Avatar
2009 19' Flying Cloud
Salem , Oregon
Noisy refrigerator fan
We have a 2009 19' Bambi. Our biggest complaint is the noise from the fridge fan. Does anyone have a tip on a good replacement fan, how to make this one less noisy, etc?
kathyek is offline   Reply With Quote
Old 10-08-2011, 12:33 PM   #2
2002 19' Bambi
Lafayette , California
There has been considerable discussion in the past about those noisy fans, so try a search on "refrigerator fan" or "noisy fan." You could start here: http://www.airforums.com/forums/f425...fan-36897.html .
Tim
Tim A. is offline   Reply With Quote
Old 10-08-2011, 12:44 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Yes, it has been discussed much here ... you are not along......we replaced ours with the Snyder Fan Kit. See the link above. It helped a lot, but there are still times when we shut it off.
TB & Greg and Abbey Schnauzer
#3954
Old 10-08-2011, 12:55 PM   #4
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
I used some of that pick packing material between the bracket and the mounting surface and it really helped. It has helped a lot.
subfan1 is offline   Reply With Quote
Old 06-27-2012, 10:05 PM   #5
kathyek's Avatar
Salem , Oregon
We bot the Snyder fan and it is so quiet we forget about it. Thank you Snyder!
Old 06-27-2012, 11:11 PM   #6
BAAMbi7's Avatar
2012 16' Sport
2016 25' Flying Cloud
Scottsdale , Arizona
We just took ours in for the same concern. But we actually addressed the issue a few months ago when they simply tightened the support beam that was loose. Now, they installed a rubber gasket - or similar rubber material between the support beam and the fan. This may - hopefully WILL- absorb the noise it's producing. If not, we'll deal with it then and take other steps.
BAAMbi7 is offline   Reply With Quote
Old 06-28-2012, 03:15 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can try a 24 volt computer fan. It will not run as fast, and won't mae as much noise. You can also install a resistor or potentiometer ( electronic rheostat) to reduce the voltage to your existing fan. Less voltage = less speed, and less noise.
Old 06-28-2012, 06:08 AM   #8
bovk's Avatar
2011 20' Flying Cloud
Beaumont , Texas
Without checking previous threads, I wired second regular computer fan in series with the existing one, both hang on flex support, no noise.
bovk is offline   Reply With Quote
Old 06-29-2012, 05:31 PM   #9
TahoeStream'n
subfan1's Avatar
Can you define "Flex Support"? Is it something that can be bought somewhere? I've never heard of that.
THX
Old 06-29-2012, 06:27 PM   #10
2008 23' Safari FB SE
Boulder , Colorado
Ours was driving us crazy too. I ordered two low decibel fans based on recommendations on this forum, fashioned a new aluminum mounting bracket and installed them. It makes a world of difference. I am mechanically inclined so the project was not too tough. At a minimum, have someone replace your current fan with a low decibel fan if you are not mechanically inclined...
bonginator is offline   Reply With Quote
Old 06-29-2012, 06:38 PM   #11
Boulder , Colorado
We did the silenx iNstall ourselves. Here is the thread that gives input on how that is done.
http://www.airforums.com/forums/f425...lly-11811.html
Old 06-30-2012, 03:57 PM   #12
bovk's Avatar
Beaumont , Texas
Flex support
THX
Sorry but this is just an improvisation - a piece of rubber to fasten to where the first fan was and to fasten both the new one and old one to it. I am sure you can figure it out, there is plenty of space and all wires are 12 volt so no danger. I would show pictures but I am about 5000 mi from my camper.
The rubber "bracket" is nearly no cost and the computer fan is about $15. I think in series they run at lower rpm but for sure with no noise. I had this for a year or so.
I should measure the drain of the fans, so far I did not use the fans when on battery. Running of the fans only improves the efficiency of the fridge cooling (using less gas).
Should I be worried about a noisy converter? J5MM 2006 Safari SE 8 03-13-2018 09:19 AM
Noisy Air Conditioner gtc6452 2011 - 2015 International 10 09-30-2011 03:02 PM
'Rugged' styling of current full size pickup trucks tpi Tow Vehicles 45 08-28-2011 09:29 PM
Noisy pump? Check this out. zedex Water Heaters, Filters & Pumps 20 07-23-2011 07:04 PM
