Old 11-13-2006, 01:35 PM   #1
1977 31' Sovereign
monroe , Michigan
noisy radio
Just purchased a 1977 AS and installed radio in provided space and very happy with the sound until I turn on any lights or fans that uses univolt ,then static starts and the more you turn on the static increases. When just using 110volt light no problem.
BINDER is offline   Reply With Quote
Old 11-13-2006, 01:40 PM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forum and congratulations on your new Airstream. Sounds to me that you have a loose or bad ground somewhere in the 12V circuit. Start off by cleaning and tightening the contacts.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 11-13-2006, 01:45 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
I have a similar problem that is set off by turning on the vanity lamp.... think this is from the same type ground problem?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 11-13-2006, 02:05 PM   #4
Check and see if the radio circuit is on the filtered circuts on your univolt.
OakHill is offline   Reply With Quote
Old 11-13-2006, 02:44 PM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Radio Noise
Greetings Binder and welcome. I guess you didn't know, any Airstream built prior to 1980 had a footnote on page 38 of the owners manual stating radio interferance caused by want to hear and see at the same time could occure after sunset!
Actually, you are suffering from a ground fault. The first place to look is at your radio, be sure the unit is grounded to the electrical system or trailer chasis. If it is then you need to start looking around your inverter for a loose ground wire. Best to start first thing in the morning because every wiring job I have taken on lasts all day!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 11-13-2006, 02:59 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Based on my personal experience, a ground fault is not the big problem. I had the exact same issue when my Univolt was in service. After installing a WFCO converter from bestconverter.com, the problem diminished significantly.
Replace your Univolt.
Tom
Old 11-13-2006, 03:00 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I've noticed something kind of similar in my '73...except it isn't static; sometimes, when you turn on a light, the sound disappears completely. Turning off the offending light sometimes makes the sound come back...sometimes I have to "re-boot" the radio. (this is a more modern-day...early 90's car stereo). I say "sound goes away" because the radio doesn't shut off; the lights are all still on. just no sound. I checked and checked and checked the ground, too.
I figured that it probably had to do with a modern solid-state electronic device being fed by a not-so-modern univolt...doesn't like the "quality" of the power its getting...voltage swings, spikes...whatever. I've also noticed that my ac/dc tv, when running on dc, has a tendancy to just shut itself off in response to any voltage dip. gotta have a fully topped-off battery to use it, which, of course, doesn't last long.
Even though the univolt "seems" to be working properly on my trailer (when hooked to shore power, 13.5 volts at the battery whenever I check it), its on my list to replace, just for improved battery maintenance alone. I was hoping it might solve these other "bugs" too, but maybe not.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-13-2006, 03:02 PM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
a-HA! Tom posted before I could finish my reply: maybe it IS the yoonie-volt.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 11-13-2006, 03:35 PM   #9
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
You can try this.
If the radio/TV is running off the 12VDC you can put a small .001 ufd 200 vac capacitor across the +12vdc side and ground. If this helps but doesn't fix the problem try a .01 ufd. This type of problem can sometimes be very hard to isolate with out proper equipment.
If you know any ham radio operators they can give you additional tips to filter out the noise and should have the parts you need in their junk box.
Garry
Old 11-13-2006, 03:36 PM   #10
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Thank Heavens
I have been having this problem since I put in my new stereo. I have been afraid to start looking, it is a relief others have had this same problem. Sounds like time to put in a new converter unit.
Rodney
and the
My Blog
Old 11-13-2006, 03:42 PM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by garry
...you can put a small .001 ufd 200 vac capacitor across the +12vdc side and ground.
a WHAT?
and you want me to put it WHERE?
seriously...I assume this attaches somehow to the 12v receptical? does it filter "noise", or just voltage spikes?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 11-13-2006, 04:23 PM   #12
TomW's Avatar
1967 26' Overlander
Spikes are really not the issue; old technology is.
Assuming a non-polarized capacitor, a value that small will basically short spikes from the higher potential leg to the other leg. Nothing hazardous mind you.
One can play with caps & chokes all day and perhaps make a difference. Since I apparently prefer to learn the hard way, I did just that with limited success.
Installation of Randy's WFCO converter was the best move I made.
Tom
Old 11-13-2006, 04:46 PM   #13
garry's Avatar
1969 31' Sovereign
A small round capacitor about the size of a dime you can buy them at
Radio Shack not expensive and "may" fix or help the problem .
It shorts the noise (spikes) to ground before it gets into the radio.
A new converter will do a better job but much more expensive.
Garry
Old 11-13-2006, 04:49 PM   #14
1976 25' Caravanner
Campton , New Hampshire
I have the original univolt and the original Motorola AM/FM eight track in my '76 and have no static or interference . I would bet on the wiring .
ticki2 is offline   Reply With Quote
Ham Radio in A/S 53flyingcloud Phone, CB & Ham Radio 490 03-05-2019 03:13 PM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
Aquajet noisy? Why no more 3-way refrigs? Kistler Water Heaters, Filters & Pumps 5 11-24-2002 08:23 AM
Picture of Radio? Pick General Interior Topics 1 10-12-2002 06:57 AM
Old motorola radio... niftypkg General Interior Topics 1 05-13-2002 09:27 AM
