Old 11-13-2006, 04:49 PM   #15
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Binder,
If the cabinet and ground leg of the radio are good, the next guess is that you're getting some unfiltered AC "ripple" in power in. Listen to a flourescent light in a quiet room - that's a 60 cycle hum. If what you hear as static is really AC leakage onto the filtered circuit, it'll sound like it's at the same frequency. Come to think of it, most original Univolts are a BIG 60 cycle hum, and you don't need a quiet room to hear them.
Mine sounds like it's about to levitate, but it's still putting out 13.7 volts, and I try to keep on top of the batteries' water. Replacing it's on the todo list, but it's down a ways.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 11-14-2006, 07:40 AM   #16
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by ticki2
I have the original univolt and the original Motorola AM/FM eight track in my '76 and have no static or interference . I would bet on the wiring .
big difference between the original 70's radio and a modern solid-state one.
I had no problem with the old radio that was in the trailer. it wasn't "original", but it wasn't much newer than that. analog tuner, etc....
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-14-2006, 09:41 AM   #17
1976 25' Caravanner
Campton , New Hampshire
Chuck , you could be right , I'll be interested in the out come , contemplating some additions also
ticki2 is offline   Reply With Quote
Old 11-14-2006, 06:51 PM   #18
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi, Chuck,
The "Motorola Entertainment Center" used in the 70's WIS an all-transistor device. All of that with nary a single chip, but we can still call them solid state.
Klaatu barada nikto
Old 11-15-2006, 08:19 AM   #19
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, I knew that probably wasn't the right terminology. but there's somethin in those microchips that makes them very sensitive. I would guess its a protective mechanism. I know on pc motherboards, if the voltage on any of those leads on the 20-pin power plug are off by as little as a few milivolts, the power is cut off to the whole system.
Air:291
Wbcci: 3752
'73 Safari 23'
Ham Radio in A/S 53flyingcloud Phone, CB & Ham Radio 454 11-25-2017 12:36 AM
Correct speaker placement, radio antenna, etc. barbwire All Argosy Trailers 0 11-29-2002 06:28 PM
Aquajet noisy? Why no more 3-way refrigs? Kistler Water Heaters, Filters & Pumps 5 11-24-2002 08:23 AM
Picture of Radio? Pick General Interior Topics 1 10-12-2002 06:57 AM
Old motorola radio... niftypkg General Interior Topics 1 05-13-2002 09:27 AM
