Old 11-09-2006, 08:53 PM   #1
soldiermedic's Avatar
Florissant , USA
No Univolt, no battery YIKES!
My 68's P/O conveniently threw out the univolt since he said it didn't work. There is also NO Battery. So how does the power work? He has a battery charger he got at Walmart....plugs it into the external power outlet, ties those lead s to the battery terminal leads and plugs into the house.
There are several open wires under my lav sink where I assume the Univolt was originally. I cannot see how this setup is efficient since the lights get very dim when all are on. What are my options here? Without the univolt front panel I really can't get intellipower.
Any help would be really nice.
SM
soldiermedic is offline   Reply With Quote
Old 11-09-2006, 09:19 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Search for Intellipower...
I'll let some of the other vintage unit owners talk about installation, but if you use searchtab above for intellipower, you'll see a number of messages on topic of replacement power supply/chargers.. Intellipower is a common model used to replace Univolts.. Since all the lighting and appliances require 12 V power, using abattery charger is a "sub-optimal" solution, and shouldn't be taken on the road... Sounds like you may discover other interesting and creative fixes made by your PO (Prior Owner..)
And, you will need a battery as a reservoir of electricity to avoid dimming experience... Many opinions about them as well, though consensus is at least "Deep Cycle" type, and maybe gel cell or glass mat if you don't enjoy maintaining batteries...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 11-09-2006, 09:21 PM   #3
Florissant , USA
How many volts would this battery charger be supplying? I need a new multimeter!
Old 11-09-2006, 09:30 PM   #4
1988 25' Excella
Images: 13
Chargers/Pwr SUpplies typically ~ 13V
Most chargers use floating voltage to bring battery to full charge and then quit providing more charge power to battery... More interesting question regards Ampere load, since portable battery chargers are often rated at 20 Amps or less, and load from all the lighting in the trailer plus appliances could approach significant portion of that... Battery is usually rated to deliver 500 + amperes for one hour, depending on size... Physical sizes desribed by "Group Number"... Common RV batteries are Group 24 or 27..
Condoluminum
Old 11-10-2006, 10:36 AM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Intellipower..
you don't need the front panel off the Univolt - just get a 12v fuse block (available at any autoparts store) - I got a 6 fuse model. The power lines of the IP go from the IP to the battery and the power block. Do a search on Intellipower, I posted a diagram of my setup. Granted, it's an Argosy, but all the same principals apply.
The IP just plugs into the 120v system from a three prong plug.
Marc
Old 11-11-2006, 08:42 AM   #6
Florissant , USA
I can get that fuse panel, but all of the wires are pretty much just "Hanging around" if you know what I mean. The wiring diagrap in my owner manual isnt specific enough to tell me where they all belong. Just a pain in the butt if ya know what I mean (I can't imagine anyone on this forum saying they haven't had a pain with their A/S).
SM
Old 11-11-2006, 10:17 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
68 Overlander (Randy) is a good resource. See his business links at http://www.airforums.com/forum...verlander.html
You really wouldn't have wanted a Univolt as old as this anyway!
5 meter Langford Nahanni
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 08:41 AM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 08:31 PM
