Old 01-09-2013, 04:34 PM   #1
1972 29' Ambassador
Waverly , Ohio
no shore power through Univolt
I have 115 volts going into my univolt at the bottom, the univolt is humming, I have power to my lights inside with the trailer battery but the battery runs dead when plugged into shore power. Bad Univolt?? Any suggestions on what else to check if anything? Thanks
Horsley1 is offline   Reply With Quote
Old 01-09-2013, 04:40 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Fuses, especially the 50 amp ground fuse.
Old 01-10-2013, 08:54 AM   #3
1972 29' Ambassador
Waverly , Ohio
It's hard to get to that fuse but I will check it this evening but if I have power from my battery running my 12 volt system wouldn't that fuse be ok? I'm not sure... Everything works as it should except when plugged into shore power it's not charging the battery or running the 12 volt system. It continues to work just off the battery until I unhook the battery then I lose all 12 volt power.
Old 01-10-2013, 10:31 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If it is the original Univolt. It may be a good time to upgrade.
TG Twinkie is online now   Reply With Quote
Old 01-10-2013, 01:38 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If it is the original Univolt, it is always a good time to upgrade...
Richard
Shore power requirments for trailers Mrcrowley Generators & Solar Power 21 08-02-2017 05:20 AM
Electrical: Shore power wont work SteveandSam Classic Motorhomes 3 01-15-2012 07:31 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Complacency In Today’s Economy Spells Vanishing Tanks and/or Shore Power Cords! overlander64 Our Community 34 08-18-2011 11:58 AM
HUM from radio when hooked to shore power The Driver Audio, Video & TV 5 07-12-2011 05:42 AM
