Old 09-12-2005, 09:17 AM   #1
Craftsman
Guest
Posts: n/a
No Running Lights
The 15 amp running light fuse in my Suburban blows everytime I plug the trailer up. No running lights on the trailer. Any ideas? thanks
Jack
Old 09-12-2005, 09:50 AM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
"New" Trailer?
Could be a miswired umbilical (if this is a new to you trailer). Otherwise, got to be a short somewhere. My vote is the short would be in the trailer someplace. Have you looked at the inverter? I believe the running lights on my '73 are on a seperate ckt coming off the Univolt. I can take a look when I get hone tonight if you need. But there's a lot of years between out TT's. Good luck.
www.nesa.org
Air No. 6427
Old 09-12-2005, 12:27 PM   #3
jimmickle's Avatar
2000 31' Land Yacht
Sure sounds like a short in the trailer. Did the Suburban work OK with a previous trailer?
The first thing that I would do is check the resistance between the running light and ground contacts on the trailer connector. If it is zero, you have a short. The problem is finding it! A short finder from your local parts store or J. C. Whitney could help you find the location of the short. Check the trailer cord for cuts/wear that may be causing a short.
jimmickle is offline   Reply With Quote
Old 09-12-2005, 12:55 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Press & Seal
I had a problem with moisture in my trailer plug, but Glad Wrap's "Press & Seal" solved the problem. Whenever I unhitch, I wrap the plug. Keeps out moisture, bugs, whatever. It's great for all kinds of things around the trailer and really does take the place of plastic bags, tupperware, etc.
(Of course it looks a little like my umbilical is wearing a condom!)
Tin Lizzie
Old 09-12-2005, 02:14 PM   #5
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
If all that fails you may have to start pulling off running lights one at time and look for a bare wire touching the skin.
They are supposed to have gromet on the wire where it exits the side of the trailer but its possible that it could be worn away, or that someone else replaced a light and did not protect the wire.
-Tim
theVAP - Airstream Podcast
Old 09-12-2005, 07:47 PM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
No Running Lights
Greetings Craftsman!
I had the same problem with my '99 Suburban/'64 Overlander combination. Lost track of the number of running light fuses that were blown before discovering the problem. The last resort was disassembly of Bargman connector on the Suburban -- corrossion had briged between terminals on the connector and was causing the fuse to blow shortly after the trailer was connected. In my case, replacing the Bargman connector on the Suburban solved the problem (I now carry a spare for the car end of the connector as this problem has repeated about every 50,000 miles -- just about time to replace the current connector as the Suburban is up to just over 153,000 miles).
Good luck in finding the culprit of your blown fuses!
Kevin
Kevin D. Allen
AIR #827
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
Blinking Galley Lights ViewRVs Mechanics Corner - Engines, Transmission & More... 7 06-23-2002 08:42 PM
