Old 10-12-2019, 05:54 AM   #1
2019 19' Flying Cloud
Apex , North Carolina
no power to Thermostat
Our less than 1 year old FC 19CB has a perplexing electrical problem. Yes it is under warrantee but we had reservations for the Smokies next week and have no ability to use heat.
We discovered the thermostat, the front fantastic fan and the TV booster do not have power. All else 12volt works, batteries good, fuses checked.
Any Ideas?
Bill n Rose is offline   Reply With Quote
Old 10-12-2019, 07:58 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Any Ideas?
Hi
If the fuses are all good (as checked with the ohms function on your multimeter) and you have voltage at the fuse sockets (as checked with the multimeter), then you have a loose wire. It's either a loose power wire or a loose ground. It could be multiples.
To check this, measure both sides of the power at each device. Check it to a convenient location on the skin of the trailer. If you get nothing on both sides, it's an open power wire. If you get +12 on both sides (with the device turned on) then you have an open ground. (If you get +12 on one and zip on the other, either the device is turned off or all is well ....)
Once you know which wire you are after, you can chase them down by looking here and there. Since they run behind the walls, this usually is a "tug tug .... did it move?" sort of thing with a helper doing one end and you doing the other.
My guess would be an open ground, but that's only a guess.
Old 10-12-2019, 12:04 PM   #3
no power to thermostat
Thank you so much for your reply.
My husband is up on the roof with the AC unit and wants to know where the AC ground wire is. There is a hot pink wire secured to the frame of the AC housing with a black end . It plugs in where it says outdoor temp sensor. We thought that was the ground before we saw were it was plugged in.
I should also tell you that he " fixed it " temporarily a couple days ago when he was up there randomly giggling wires. We thought he was a genius.
We will let you know if we make progress.
Old 10-13-2019, 06:07 AM   #4
Uncle Bob
We have checked found that the wire on the roof that my husband giggled to result in temp fix is the outdoor temperature sensor. He will climb up there later and get it to test it with the meter.
we will report back.
Old 10-13-2019, 08:20 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
With multiple items not working, there is probably no power or a bad ground connection on a circuit which is fed by one of the fuses. Check the connections at the fuse panel for tightness. Check the nuts on the connections to the fuses and find the ground buss bars in your power center and check the screws that hold the wires in. Beyond that it may be a connector between wire harnesses between the walls.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-13-2019, 09:29 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Any Ideas?
I suggest starting at the fuse panel and working outward on the circuit that is problematic. After confirming which circuit is the issue >
1. confirm fuse is good in that circuit
2. confirm the (+) wire is connected correctly to the fuse panel
3. go the first piece of equipment on the circuit and confirm that the (+) wires are connected properly
4. go to the second, third, fourth, etc... do the same.
Each piece of equipment is grounded directly to the trailer structure/skin. There is no common ground wire between them (at least that's the way it is on my trailers), so it is unlikely that all three items you mention have lost ground at the same time.
Good luck!!
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 10-13-2019, 09:44 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Uncle Bob
You mentioned the thermostat, the front fantastic fan and the TV booster have lost power. Jiggling the wires on the roof would have no affect on these.
Both the 120v and the 12v power supplies to the roof top AC unit comes from beneath the AC unit. On my trailers I have to check these by removing the interior cover. There is a yellow Romex NM cable supplying 120v power, with black supply wire, white neutral wire, and bare copper ground. Not sure about your trailer, but on mine there is a black/red wire providing 12 volt (+) power.
Alan
Old 10-13-2019, 09:56 AM   #8
Unhappy no power to thermostat
Thanks to all who are trying to help! We will be rechecking the fuses and connections. We will recheck the buss connections. So far all has tested good except not getting 12 volt to thermostat, antenna booster and front fan which are all on the same circuit as the AC.
As noted before, jiggling the outdoor temp sensor in the AC gave us a fix for several days but after the trip home the Jiggling doesnt do anything to fix the recurrence.
At this point we are no longer Giggling over the problem
Old 10-13-2019, 01:25 PM   #9
Half a Rivet Short
Hi
The wire you are giggling likely is moving another wire that's moving another wire .... Eventually it gets to the wire nut or broken wire or loose screw that is creating he problem. The only way to debug it is to follow through the circuit and figure out where the loose connection is. Since Airstreams are all a bit different, you will need to track things down as they apply to your specific trailer.
Old 10-13-2019, 10:15 PM   #10
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
I would tighten all electrical connections. It is amazing how many time several are missed and it is not just Airstream, but vender supplied components as well.
guskmg
Penguin 2 & CCC2 Install- No Power to Thermostat emmadow Electrical - Systems, Generators, Batteries & Solar 1 07-15-2018 06:38 PM
No Power to rear Fantastic fan thermostat jimmymac Our Community 1 08-25-2017 08:46 PM
12V Power for AC Thermostat in 72 Sovereign goobscoob Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-07-2016 08:18 AM
No power to thermostat jerhofer Sprinter and B-van Forum 23 08-04-2015 10:03 AM
No Power to Thermostat? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-20-2009 08:53 PM
