Old 01-25-2012, 01:04 PM   #1
1975 31' Sovereign
Pinson , Alabama
No power to outlets
Hi I could use some help. Everything worked when I went to sleep last night but when I woke up, realized that none of the outlets have power. Lights and fridge have power just not the outlets. PLEASE let me know if you know to fix this!!
hnspaulding is offline   Reply With Quote
Old 01-25-2012, 01:09 PM   #2
azflycaster's Avatar
1975 25' Tradewind
Phoenix , Arizona
Images: 67
Check the breakers, especially if you have a GFI breaker.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 01-25-2012, 01:12 PM   #3
1975 31' Sovereign
Pinson , Alabama
Yeah I flipped all the breakers but that didn't help so I'm thinking one needs to be replaced. I'm a 24 yr old girl and really just dont know how to fix things like this.
Old 01-25-2012, 01:24 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Did you reset the breakers in the trailer or at the shore power box? Is the shore power breaker a GFI type. What year is your trailer?
Old 01-27-2012, 05:47 PM   #5
1975 31' Sovereign
Pinson , Alabama
Its a 75 landyacht. I got it fixed. It turned out the power box outside shorted and fried my 220 plug. Just had to wire in a new one and run an extension to a new box. Thanks for your help though!
Old 01-27-2012, 06:27 PM   #6
1975 25' Tradewind
Phoenix , Arizona
Images: 67
Glad you got it working, but it is not a 220 plug or outlet. It is 120 volts 30 amps.
Richard
Old 01-27-2012, 06:49 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1998 30' Limited
1947 22' Liner
Valley View , Texas
Images: 47
Hope you are NOT using a 200 or house type appliance outlet. If so.....we will hear from you again.
Melody Ranch is online now   Reply With Quote
Power Loss & Pets Inside? Frank&Mike The Pet Forum 51 05-10-2012 08:34 AM
Half of the outlets have no power VeggieBullet Electrical - Systems, Generators, Batteries & Solar 23 01-22-2012 08:08 PM
No power to 12v outlets on Dash dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 12-12-2011 08:50 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
