Old 02-19-2012, 01:02 AM   #1
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
No power to bedroom side A/C outlets
does anyone have a wiring diagram for a 1976 Argosy 26'. The bedroom and bathroom a/c outlets have no power.
susans69 is offline   Reply With Quote
Old 02-19-2012, 08:14 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you start removing panels open the effected receptacle closest to the ac panel and locate the feed fire coming from the panel. This can be do by turning the power on and testing the black and white wires of each of the cables coming into the wall box. If you see power on a pair of wires the problem could be a loose connection on the receptacle you just removed to do the test.
If you do not find power go to the inside of the ac panel and make sure all connections are tight there and retest.
If both tests fail the wire itself is broken somewhere in the walls.
If this is the case you can go one step further. Remove power from the trailer and lift each wire off the fuses, you do not have to lift the white wires off the neutral block. With a length of wire long enough to reach from the ac panel to the receptacle test for continuity on each wire in the receptacle back to the wires in the panel. You should be able to locate at least one side of the wires in question, as it is unlikely that both sides will be broken.
If you can only find one side as good then you are in for some panel removal and rewiring.
WBCCI 12156 AIR 3144 WDCU TAC NJ6
2004 Excursion 4x4
1991 34 ft. Excella +150,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
My Kayak mysite.verizon.net/vze54tx9/kayak/
Old 02-19-2012, 08:50 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you checked to see if a circuit breaker has tripped? Do you know where the power panel is located?
Solar Power Quest Mr & Mrs S Boondocking 58 03-02-2012 02:03 PM
Special Ops Mission CA to TX Mr & Mrs S On The Road... 56 02-22-2012 07:41 AM
No power to bedroom side A/C outlets susans69 Electrical - Systems, Generators, Batteries & Solar 2 02-19-2012 08:50 AM
2003 Airstream 22' International CCD Repairable Clear Title NO RESERVE eBay Watch Airstreams on eBay 0 02-18-2012 07:40 PM
Going to NYC (Manhattan). In need of accommodations. carmanahwoo On The Road... 1 02-18-2012 07:07 PM
