Old 09-11-2007, 07:23 AM   #1
UK Airsteamer
finn2020's Avatar
1976 25' Tradewind
london , UK
No power on light on control box
When I connect via shore power the power on light does not come on. The 120v sockets, aircon, fridge and 12v sockets work - The battery does not seem to be charging - Is the univolt faulty?
finn2020 is offline   Reply With Quote
Old 09-11-2007, 08:55 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
hi- If your battery is not charging when connected to shore power, then either the converter is not working properly, or the battery is shot. I think the "power on" light should work though, check the bulb and fuses. A good new converter is the "Intellipower" unit, sold here by a forum member. Good luck, doesn't sound like a tricky problem.
tphan is offline   Reply With Quote
Old 09-11-2007, 03:52 PM   #3
The "power on light," can burn out.
Or, if someone changed out the univolt, they may have used a charger that does not operate the power on light.
What converter is in the trailer?
Old 10-08-2007, 05:46 PM   #4
AronS's Avatar
2007 25' Safari FB SE
Petaluma , California
I have the same thing going on--I replaced my Univolt with an Intellipower unit several months ago and the light worked before but when I replaced the Univolt there was a spare wire left over but I didn't know to what that should go--I vaguely remember trying to hook it into +12 volts on the Intellipower but that didn't light it. Anyone know to what it should go?
Aron
AronS is offline   Reply With Quote
Old 10-08-2007, 06:59 PM   #5
richinny's Avatar
2011 34' Classic
do a search for "wall wart" and intellipower. your answer is out there!
Ricky
Old 10-08-2007, 08:00 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If I read you correctly, you have no pilot light AND no charging. If that is so, then it sounds like the univolt is not connected or not working, that is, if you have the original type univolt. If it was converted to one of the newer switching power supplies, then the telltale may not be hooked up and there may be a blown fuse. You'll need to get out the old voltmeter and see what's what.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-09-2007, 09:39 AM   #7
AronS's Avatar
I just re-read the original post, my situation is different--sorry about that!
I have a new Intellipower and the 110 volt and 12 volt circuits are working correctly. My question is how to illuminate the control center panel charging/shore power light when the Intellipower is plugged in and providing 12 volts, just as the Univolt did.
Aron
Old 10-09-2007, 04:40 PM   #8
richinny's Avatar
2011 34' Classic
aron
see if this helps
post #9
http://www.airforums.com/forums/f449...olt-33136.html
Ricky
Old 10-09-2007, 05:08 PM   #9
AronS's Avatar
Thanks, Ricky, I will try that out. Grounding the lead was the one thing I know I didn't try. I guess it is within reason after I discovered that was how the porch/step light worked too (always hot with a switched ground).
Aron
Old 10-09-2007, 09:12 PM   #10
richinny's Avatar
2011 34' Classic
be careful! remember that you have two electrical systems. one system is 12v dc and the other is 120v ac.
Ricky
Old 10-11-2007, 02:26 PM   #11
1970 25' Caravanner
Rutherfordton , North Carolina
How would I know if my converter has a charger or not?
I don't mean to change the subject but, if my battery is dead and still hooked up in line to the converter and the tow vehicle is hooked up to the camper, would this cause the running lights not to work?
steve hughes is offline   Reply With Quote
Old 10-11-2007, 02:34 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I am going to assume that you are towing and your running lights are not working. In that case I doubt that your convertor is hooked to shore power. The battery should charge from your truck.
Either way, makes no difference. Your running lights get their power from your truck. If they are not working, check the plug from the truck to the trailer.
Richard
Old 10-11-2007, 03:01 PM   #13
1970 25' Caravanner
Smile running lights not working
Thanks for the reply.
So I know my battery is dead and you are saying that it does not matter because the power from truck does not go thru the battery for the running lights. Its like a non camper trailer with lights wright?
Old 10-11-2007, 03:04 PM   #14
2002 25' Safari
Dewey , Arizona
Images: 62
Correct. Brakes, running lights, brake lights and turn signals all are powered from your truck.
Richard
a call for layouts and/or photos of AC/DC power control panels Wabbiteer Electrical - Systems, Generators, Batteries & Solar 3 11-28-2006 01:10 AM
Porch light only on Battery power???? campngirl Batteries, Univolts, Converters & Inverters 11 10-21-2006 06:55 AM
control center power '73 model marvande 1970 - 1973 Sovereign 3 07-10-2006 03:22 PM
AC power indicator light won't work. blickcd Furnaces, Heaters, Fireplaces & Air Conditioning 9 05-14-2006 07:32 AM
AC Power Light on Control Panel? 66Overlander Electrical - Systems, Generators, Batteries & Solar 8 10-20-2005 08:13 PM
