Old 05-05-2016, 03:57 PM   #1
cdufault's Avatar
1977 28' Argosy 28
Mission Viejo , California
No drill solar panel mounts SikaFlex-221 or 3M THB tape?
i am planning to mount solar panels to the top of my 1977 argosy 28 motorhome using no drill mounts design for RVs and boats. These require industrial adhesive. i'm debating whether to use SikaFlex 215 or 3M THB double-sided tape. Both have excellent reputations for permanent adhesion. The SikaFlex and other similar industrial adhesive's are used to hold windows onto the side of skyscrapers. The THB double-sided tape is used by car manufacturers to hold anything from trim to body parts. Either is recommended for my application. Just wondered if any of you have a preference and/or experience and why? Thanks.
cdufault is offline   Reply With Quote
Old 05-05-2016, 04:08 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Resident solar expert Lew is a big fan of the tape.
MICHAEL
Old 05-05-2016, 04:54 PM   #3
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Just completed the install of a solar system from AM Solar and the supplied feet have the 3m tape preinstalled and it was recommended, and I followed their recommendation, and purchase 1 tube of Sikaflex 221 to augment the tape and to seal the screw holes that are in the feet and around the edges. Nothing better than additional failsafe.
tsunami is offline   Reply With Quote
Old 05-05-2016, 04:59 PM   #4
2007 22' International CCD
Just don't clean with alcohol if you use Sikaflex. Lew advises against it.
He uses VHB tape on the foot then seals over it with Sikaflex.
KE4GNK/AE
Old 05-05-2016, 05:15 PM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I vote for properly applied vhb
Old 05-05-2016, 06:06 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
VHB tape AND SikaFlex. Carb cleaner or mineral spirits ONLY for surface prep. Also clean the tops of the rocker foot mounts.
The SikaFlex 221 serves 2 purposes after the VHB is stuck down:
1. It provides a secondary bond along with the VHB
2. It acts as a waterproof barrier to keep the VHB dry.
I've never lost a panel using this method!! 😃
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 05-05-2016, 07:26 PM   #7
Thanks for chiming in Lew, I couldn't remember the detail of what to clean with.
I'm adding panels to our AS and this time I'm using your method....😄 instead of rivets and Sikaflex like last time. (Too soon old, too late smart...)
KE4GNK/AE
Old 05-05-2016, 08:06 PM   #8
1972 25' Tradewind
fort lauderdale , Florida
Look up click bond products. They're used in airplanes, cruise ships and the military.
Great product. I think Kip can vouch for them as well.
ehodg66 is offline   Reply With Quote
Old 05-06-2016, 12:27 PM   #9
cdufault's Avatar
1977 28' Argosy 28
Lew Farber
Okay THB and 215 with carb cleaner it shall be. Now if I can only get a dry day... thanks much!
Old 05-06-2016, 12:44 PM   #10
1975 Argosy 22
Eugene , Oregon
Both - you can't go wrong, tape first followed up with sikaflex.
mrdfred is offline   Reply With Quote
Old 05-06-2016, 05:24 PM   #11
lewster's Avatar
That's VHB and 221........ to be sure!!!
Lew Farber
541-490-6357
Old 05-07-2016, 12:02 AM   #12
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
lewster is right. He did the same thing to my roof mounts. On our way home, 1,100 miles and 30 hours later with a Wally World stop, we hit 80 mph off and on because my friend needed to get back to work. A little fast for this old man, but it gave the new panel mounts a good acid test and they are still holding tight.
guskmg
Old 05-07-2016, 12:20 PM   #13
1978 28' Ambassador
Chattanoog Dee a , Tennessee
Sikaflex. We have a 1977 28' Avion with solar and have transtioned to mostly led lighting. The solar keeps the batts charged.
Ldydefleurs is offline   Reply With Quote
Old 06-20-2016, 08:22 PM   #14
tsunami's Avatar
Images: 20
Just arrived in Fairbanks Alaska. The new panels I installed, per AM Solar directions, have survived over 3 days of torrential rain in Alberta and British Columbia Canada. To include temps in the high 80,s to the lows in the mid-30's in the last three weeks and sustained 30 mph headwind while driving at 60mph. The panels have been checked and rechecked and are still securely attached and functioning as advertised.
Solar to drill or not to drill-HELP Orson Electrical - Systems, Generators, Batteries & Solar 2 08-24-2012 08:03 AM
Is there anyone who uses Trempro 636 & Sikaflex 221 on a 70's AS bennyg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-29-2011 08:16 PM
Sikaflex 221 gray? AirHog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-19-2011 12:22 PM
Drill Baby, Drill! Mount external antenna TropicGuy Computers, Internet & Satellite 5 04-17-2010 03:02 PM
SikaFlex 221 buy locally? rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 10-18-2008 05:37 PM
