Old 04-08-2015, 08:16 AM   #1
Old Lyme , Connecticut
No Battery Power
Recently purchased a new (2014) Flying Cloud 27FB. We are loving it except now, after our first week on the road, we have no power when not connected to shore power. It worked for our two trial runs of 2 and 4 days. I stopped at Interstate and had the batteries checked out, everything was a-okay. When disconnected from shore power I do not get enough battery power to run the lights, to enable the LP to run the refrigerator, etc. In short, when we are disconnected from shore power we have no power at all. Any advice before I pull up stakes in the campground and haul the trailer to an Airstream dealer?
Desperate
kdz03w is offline   Reply With Quote
Old 04-08-2015, 08:18 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Is your Battery Disconnect in the "use" position?
MICHAEL
Old 04-08-2015, 08:44 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I am assuming that your lights, TV, fridge and such work when you are plugged in. If not, then you have another issue.
Unless your battery is dead or not properly connected, the Battery Disconnect switch is the likely culprit. It does not visibly "toggle" on or off, just click it on the "on side" and see if that gets you battery power. If you don't hear a click when you push the switch then you have a dead battery or one that is not properly connected. If you get to this point, check the battery connections at the battery itself. If the battery is connected, then find a voltmeter to test the battery to see if it has a charge. It should read between 12.2 volts (indicating a 50% charge) and 12.7 volts (indicating a 100% charge.)
Bob Martel
WBCCI# 5766
Battery Good No DC Power with shore power off. Frank Ross Batteries, Univolts, Converters & Inverters 15 08-09-2014 03:42 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
