06-27-2016, 08:49 AM
2012 27' Flying Cloud
Richmond
, Virginia
No AC Power while on shore power
I hope someone has seen and resolved this issue already.
When my 2012 27 FB Flying Cloud is plugged into shore power, occasionally (currently > daily) the AC in the trailer will inexplicably stop working. That is, all outlets go dead, TVs go off and of course, the HP/AC stops. Here are my observations so far
- All things working normally
- Heat Pump/Air Conditioner (HP/AC) is running normally
- AC Power stops working sometimes with no new load and sometimes with new loads (hair dryer or coffee maker,...)
- No breaker on Parallax 7355 tripped
- Shore power to still live (per line light indicator)
To restore AC, I have tried several things:
- replaced shore cable (did nothing)
- resetting all breakers in trailer does nothing
- resetting breakers on shore power pole does nothing
- resetting battery disconnect does nothing
- Disconnecting shore cable and moving to other 30 AMP input WORKS (side input to front generator input or from front to side)
Has anyone seen this or have suggestions on additional diagnosis?
06-27-2016, 08:52 AM
Mantua
, Ohio
There's a recall or something. Wait til someone who knows the details chimes in. Transfer switch.
2013 27' FB International
El Dorado Hills
I don't know the exact reason but I'm pretty sure the problem lies with the electronics in your breaker box. There's these switches that manage the AC between the two exterior plugs. Somethings not right in there.
Sorry for the mostly useless answer.
06-27-2016, 10:01 AM
2012 25' FB International
Trent Woods
, North Carolina
There have been numerous transfer switch failures. This is a box near your converter that switches AC input between the two sockets, front and side. I carry a spare for that reason. You may be able to get the switch to transfer by rapping on the box. It is supposed to switch automatically to the socket that is powered.
Larry
06-27-2016, 10:20 AM
Princeton
, New Jersey
Just trace from the shore plug in point to where you loose power with a voltmeter. That is the point of failure.
Your one comment that changing to another 30 amp shore power post would say the original post was intermittent and the problem. Don't rely on a light, you have no idea where the light is connected, use a meter on the terminals.
2004 Excursion 4x4
06-27-2016, 11:25 AM
2016 30' Classic
Rocklin
Power issue
I have a couple of thoughts. Could there be a short in the extension cord that is fine cold but once it heats up due to use the short expands and you have a failure ?
Could the extension cord not be of sufficient gauge ? A heavy duty 10 or 8 gauge cord has less resistance. If you have a 14 gauge cord it could be an issue.
06-27-2016, 11:34 AM
1974 Argosy 26
Morrill
, Nebraska
My vote is for the transfer switch. IMHO because when you change to the other shore power receptacle, all is OK.
06-27-2016, 01:22 PM
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
Changing the shore power input was THE way to reset the transfer switch, wasn't a 100% fix. Poor switch quality, chinese mfg.
"Chip Tank" is in Westwood Ca.
06-27-2016, 01:26 PM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
I don't know if this will have any effect. But I was informed to make sure none of the outlets breaker tripped. Pay close attention to the one by sink under the mirror.
06-27-2016, 02:09 PM
2012 28' International
Olympia
This would only effect outlets on the GFI circuit. Since the OG is losing all power the likely culprit, as has been noted above is the transfer switch. It's nothing but a big relay and is prone to failure.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
06-27-2016, 04:06 PM
in the rising sun toaster
1956 26' Cruiser/Overlander
Wimberley
Same symptoms happened once, long ago, to my vintage AS camper (which doesn't have the switching inputs/relay system your 2012 has but it might still be the cause of the issue you're encountering). I traced the problem to inside the breaker box where the shore power plug's mains wires connect. The set-screw on the mains neutral wire inside my breaker box was loose enough to result in power intermittencies. Once that set-screw was tightened, there were no more dropped power issues. And from that incident, and because we off-road our trailer a lot, I added the periodic checking/tightening task for *all* the electrical connections, including lights & sockets, outlets, fans, H2O heater, aircon & heat strip, inverter, splices/junctions, all circuit breakers, mains connections, shore power plug; and then I do the same for the 12v system's connections, including house battery, lights & switches, reefer, battery charger, fan, air compressor, breakaway, brakes, & the plugs to/from my tow vehicles.
06-27-2016, 04:28 PM
2014 23' Flying Cloud
Rhinebeck
, New York
Hello,
I remember calling our Airstream Dealer to discuss the inability to run the AC on shore power (here at home). The first question asked was : " Are you sure that the source of power is on at least a 30amp "breaker""? I stammered and admitted that I had no idea. It wasn't. So, being illiterate to the technical ISSUES, all I can add is "be sure the source of your shore power" is adequate to meet your requirements. The AC needs a min of 30amps.....anything else used needs more. Always nice to have 50 amp service at compgrounds......not available from the hookup in my barn.
Cheers,
Adam
2014 AS International 23'
2011 Ford 250 6.7L turbo diesel
06-28-2016, 09:32 AM
Richmond
, Virginia
UPDATE and follow-up questions
Things got much worse. The AC was failing every 2 - 10 minutes I tested all the cables and voltages. All looked good. After disconnecting the batteries and shore power, I opened the Automatic Transfer Switch (ATS) and inspected. The internal clear plastic enclose was warm/hot and smelled of over heated/fried electronics. Due to my situation (did I fail to mention that I am on a family trip with 4 people and a dog in the middle of Florida ~ 95 degrees), I decided to by-pass the switch. In the ATS, I disconnected the shore power (side input) white and black and the switch's output white and black wires. With large wire nuts, I securely connected the w-w and b-b wires. I left the generator wires and ground wires in place. So far, AC power is holding.
QUESTIONS:
- Does the temporary fix seem appropriate (and safe)? Should I be concerned about anything? Should I be monitoring anything?
- For long term, should I replace with the same model (I think it is a 301) or should I find a different ATS OR should I get a totally new power system?
Thank you all for you suggestions and guidance.
06-28-2016, 09:47 AM
Princeton
, New Jersey
If you now have power it should be fine. The only hesitation would be if you were feeding power to the unused connection on the outside of the trailer. Check it for voltage as a safety factor but having only delt with 4 wires you should be fine.
When you are home I would go to an electrical supply house and see if they have a switch that would replace that Chinese part. I would not trust Airstream to do it correctly under a recall.
2004 Excursion 4x4
06-28-2016, 09:52 AM
2002 30' Classic S/O
Fleming Island
The only suggestion I would offer is to twist the wires for about an inch before putting on the wire nuts to ensure a good connection.
Wirenuts are used all over the wiring in my house. If there is a current rating on them it needs to be whatever your service is, or rated for the wire size you are joining since that implies a current rating.
IMHO, YMMV, etc.
Al
Al
06-28-2016, 10:10 AM
El Dorado Hills
You're a McGuyver!
06-28-2016, 11:11 AM
Mantua
, Ohio
If you are in north Florida try Sanders north of Gainesville. They will fix you up.
08-24-2016, 07:20 AM
W
, New England
Same problem here - same exact trailer/year. We did have one low voltage shutoff courtesy of the Progressive Dynamics EMS on the pole. But we've had some intermittent shut offs that weren't due to low voltage (as far as I can tell by the PD).
So I'm thinking of having the ATS bypassed at a local RV shop just to get through the rest of this season. Where exactly is this located? I hear it's either on the back of the Parallax or with the inverter? Not sure...
For the future - some folks have made mention of a manual switch. Is something like this what I'd be looking for?
http://www.boatersland.com/newssswit...FUEmhgodC5QB_A
I think this fall I'm going to have a local RV dealer swap out the Parallax and install a manual transfer switch. Just want to be sure I provide the right parts (or that the dealer can order the right parts).
Thanks for any insight you can share. If you know of good vendors/RV electricians in the CT/MA area, feel free to PM me with recommendations. Thanks!
08-24-2016, 07:35 AM
Sag Harbor
, New York
Originally Posted by SteveSueMac
. . . If you know of good vendors/RV electricians in the CT/MA area, feel free to PM me with recommendations. Thanks!
I would also be interested in shops/vendors on Long Island NY or CT/MA as above, to upgrade our converter/charger, batteries, maybe add solar, etc., so please post any leads here, and we can start a new thread if needed.
Peter
08-24-2016, 11:31 AM
W
, New England
Lewster needs to come up for a week. There'd be a long line waiting to write him checks....
#JustSayin
