Old 10-06-2016, 06:25 PM   #1
2011 25' FB Flying Cloud
Falmouth , Maine
No AC Power
I have a 2011 Flying cloud. I thought I had overloaded my shore power while running a small space heater and electric coffee machine and the heat pump kicked in. The breaker on the pole was ok and the breakers in the trailer were also ok.
I've just replaced the original converter, checked all grounds and connections in the panel, but still, no ac. DC seems to be running fine, but no charge from the shore power. I have solar and am getting charge from the solar.
Any suggestions?
Thanks for the help as I'm over my head!
DerrickB is offline   Reply With Quote
Old 10-06-2016, 06:41 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Turn breakers all the way off then back on sometimes they trip but its hard to tell without flipping off/on.
Garry
Old 10-06-2016, 07:26 PM   #3
Falmouth , Maine
Thanks Garry.
One more update, I switched my shore power from the front plug to the rear plug and now I have AC. Is there a fuse somewhere for the actual plug?
Old 10-06-2016, 11:53 PM   #4
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
The change over relay is very very week. When too much current is drawn thru it it burns the relay contact pads breaking the circuit. There is no clue that this has happened. Plugging in up front will reset it. I had the same problem on the first couple of uses of our new 2012FB. Was just infuriating. Replaced the cheesy relay with a properly rated and designed change over contactor. I documented the whole replacement process in an earlier thread. Airstream is fully aware of the problem and they should replace it free of charge.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 10-06-2016, 11:56 PM   #5
2015 30' FB FC Bunk
Golden , Colorado
Sorry if plugged in up front changing to the rear will reset it and it should work at low current. If not the change over relay is completely burned up on the front circuit contacts. .
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 10:51 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 12:52 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 09:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
