Old 08-19-2019, 07:47 AM   #1
pamu's Avatar
Cumming , Georgia
NO 12V power
We have a "new to us" 2005 25' Safari. Apparently, it sat in storage for many years before the guy that we bought from picked it up from its original owners to flip. We cannot get the 12V to work. The batteries are good and charged. We suspect that the battery disconnect behind the sofa is the culprit. It has two fuses which I changed.... The light on the battery disconnect switch by the door is always red.... (I presume that it would change to green?) Our older AS did not have this feature.
Does anyone have any insight? Before I remove the sofa (again)! Also, the fridge does not run on propane... it appears to switch to propane when on shore power, but when disconnected from power, shuts off. Could this be related to the no 12V power issue?
Thanks in advance!
pamu is offline   Reply With Quote
Old 08-19-2019, 08:19 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Fridge and WH need 12 volt power to work.
Old 08-19-2019, 10:10 AM   #3
pamu's Avatar
Cumming , Georgia
Suspected that. Thanks!
Old 08-22-2019, 06:04 PM   #4
Spokane , Washington
Our battery disconnect switch is always red unless we're off shore power and in "store." Our 12 V was recently out in our 2011 27 FB and the wiring to the disconnect soleniod was damaged and the fuse was blown. Not sure where it's located on your unit (ours was under the bed near the battery), but it could be something like that.
coltnkat is offline   Reply With Quote
12v
Victron Orion 12V to 12V converter mikedebi Generators & Solar Power 14 08-03-2018 04:44 PM
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 09:53 AM
