I'm using an adapter at the end of the argosy to take the cord from a 30 amp plug to a "regular" sized on and plugged into the KOA power. Their recepticles are bigger and appear to be 50's, therefore my cord does not work....c,Lear?
If you are plugged into the regular (looks like an outlet in the home) outlet, it will be GFIC protected, as well as having a 20 amp breaker. Check both, the breaker and the GFIC reset. If you have not plugged your Argosy into a GFIC in the past, it could have a problem due to some leakage.
You also could go to the park office and see if you can rent or borrow a 50 amp to 30 amp adaptor.
