Old 03-16-2013, 03:59 PM   #1
Elberta , Alabama
No 110 outlet near univolt
I recently bought a 79 Sovereign (basket case).
There is no outlet near the univolt
(the uinvolt is missing) It appears the coach
was used with solar power only, and that was
(MICKEY) at best.
There are outlets on either side of the coach,
but none near the center.
Am I missing something or do I run a cord to
one side or the other when I install a new converter?
hippietye is offline   Reply With Quote
Old 03-16-2013, 04:17 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Our 63 was wired direct.
I would use 8gauge copper minimum. Anything over 6', go one larger, (lower #)
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-16-2013, 04:22 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Strange, my 1979 Safari has the univolt under the fuse panel in the front between the batteries. There is a 110V outlet there. I looked at the 1979 Service Manual and all lengths of 1979s appear to be the same.
Bill
(MICKEY) at best.
Just my personal opinion
Old 03-16-2013, 04:49 PM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
My 77 Safari has the univolt in the center under the Gaucho, there's a receptical to the left (battery is on the right)
I believe the Soverign was the same layout that year.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 03-16-2013, 04:55 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If the Univolt is missing, how do you know that there's not an outlet near it wherever it is? Sorry, just couldn't resist.
Bill
Actually, it may be just not knowing where to look since it is missing. My 1983 Excella's was located in the same place as Bill's. That location is behind the couch, though, and it is not obvious while the couch is in place.
Here's a photo I took while I had the sofa removed:
I replaced the Univolt with a Progressive Dynamics Inteli-Power. Completely silent and provides clean 12v DC. Great upgrade.
Vaughan
Old 03-16-2013, 04:57 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
That is exactly where the univolt is in my 1979 Safari. Drop the couch down and there is an access plate on the shelf. Take out a couple of screws and the univolt and outlet are there.
Bill
Old 03-18-2013, 02:44 PM   #7
Elberta , Alabama
Thanks to all who replied to my thread!!!
After a lot of looking and learning some
new language I figured it out.
(1) I had to remove 2 runs of 4/0 cable,
2 runs of #8 cable and other miscellanies
wires (5 of them) all well siliconed to a
plastic battery box that had been added.
(2) Remove the battery box—6 screws in
the bottom, screws out, the box still wont
come out. there is an eyebrow on the
front covering a vent for the battery box
5 more screws, pry the eyebrow off,
back inside, the box comes out,
still no outlet. the battery box was
mounted tight to the outer panel.
(3) A cold beer and a sandwich—Cool off.
(4) In feeling underneath the inner panel near
the fuse box. Out comes a length of romex wire,
caped and well taped.
Then with further inspection,I pull on a piece of
duck tape,and down comes the ends of 4
battery cables. The outside boxes were not
being used,a single center battery was being
used with the solar system
(5) Now I can get on with the original project!!!
