Old 06-21-2009, 01:28 PM   #1
Mt. Angel , Oregon
Newcomer needing help
I just picked up a 1974 20' Coachman travel trailer and i am kinda baffled. When i have the 110 plugged in i have 12v lighting and other 12v functions, but when i unplug the power cord it should run these things off of the 12v battery, correct?? I have no 12v from the battery. Battery is charged and yet no functions. Can anyone please shed some light??
dman67 is offline   Reply With Quote
Old 06-21-2009, 01:44 PM   #2
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Fuses? Corroded connections?
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 06-21-2009, 05:06 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Hi Dman...
We're mostly about all things Airstream here, but electrical problems are pretty common ground among all trailers... sounds to me that since all your 12v systems are working with the converter, you've probably got a ground issue for your 12v battery... less likely would be the positive side. 99.5% of all 12v problems are ground-related. The other .5% are ground related too.
It could be corrosion, bad connections, bad cables... even a fuse or fusible link... just get out your 12v VOM and start tracing!
Good luck figuring this out!
Roger
Old 06-21-2009, 06:00 PM   #4
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
What about when you have it hooked up to the TV do you have power then? It is not a solution but may help you narrow down the problem. The TV should give the lights juice under 12V. Maybe the battery is not connected to the converter?
nick6930 is offline   Reply With Quote
another newcomer pfflyer Member Introductions 7 08-24-2008 09:58 AM
Newcomer mrauch Member Introductions 7 05-12-2008 07:27 AM
Newcomer BOWTIEMAN 540art Member Introductions 3 10-31-2006 10:58 AM
Newcomer aerodynamic Member Introductions 2 07-31-2006 02:36 PM
Newcomer says Hi amanda1 Member Introductions 4 07-09-2006 06:45 PM
