Old 02-05-2010, 06:58 PM   #1
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Newbie Question
I am going to be purchasing a 2010 16' Sport in the coming month.
Seeing as though I have yet to view my trailer, and I am trying to set up my tow vehicle, what kind of wiring should I add to my truck?
Is it a seven pin round connector? Does that include the charge line for the trailer battery?
Thanks in advance for your answer.
boutdoors is offline   Reply With Quote
Old 02-05-2010, 07:07 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome aboard....
Good luck with your toy....keep us posted on your adventures
Stream Safe.....
Trailer Wiring Diagrams
seven pin trailer connector - Google Product Search
Trailer Brake Controller Information
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-05-2010, 08:07 PM   #3
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
From what I can tell it should be a 7 flat pin connector?
Old 02-05-2010, 11:21 PM   #4
Your Bambi should have the round 7 pin plug.
PFC
"Tahawus"
RLC
John Prine
Old 02-06-2010, 09:08 AM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Yes, it's a 7-pin round. Yes, it has a charge line for the battery. If you will be doing a lot of boondocking I recommend you have the dealer change the 24 battery to a 27. It'll last a lot longer.
Ahab is offline   Reply With Quote
Old 02-06-2010, 05:33 PM   #6
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
new 1s are coming with 7 pn pollach plug, has 6 flat and center round. is wired to pollach code. hint if setting your tow vehicle up i recomend you put male female spade connectors on green and brown wires,right turn & running lights as there are 2 color codes used these days. bargman & pollach the differance between them is these 2 wires are reversed . if you use spade quick connects on these 2 wires it is a small affair to alter to tow different trailers , and it always seams that no matter which way you go you'll need it the other way. when in ca. it was rare to see anything but bargman code = brown run, green right turn or is it the other waygreen run and brown right turn . lol
crestonrv is offline   Reply With Quote
Newbie question AMCDeac Our Community 1 05-26-2009 08:00 PM
NEWBIE Question: What to Look For??? mistermike 1959-69 Tradewind 2 09-03-2008 09:18 AM
newbie question goransons Waste Systems, Tanks & Totes 5 07-22-2007 04:05 PM
Newbie has a question CTHilmo Member Introductions 17 03-14-2006 03:07 PM
Newbie question Old Nick All Argosy Trailers 5 05-17-2005 06:21 AM
