Old 02-16-2015, 12:21 PM   #1
2010 25' FB Flying Cloud
Snoqualmie , Washington
Newbie - Plug For City Power?
Have my 2010 25FB AS parked at my house - getting ready for it's maiden voyage. I realized i plugged power from my house into the AS in the front, what the AS manual says is for generators. Things seem to work - so what is the difference between this generator input and the city power input on the side of the Airstream. Any drawback when comping plugging camp power into the connector in the front?
Anders79 is offline   Reply With Quote
Old 02-16-2015, 12:27 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think they call the front one a generator input because it's closer to the tow vehicle where you might be carrying your generator, and shore power poles are often located closer to the back of a campsite. As long as the automatic transfer switch is working, it doesn't matter which entrance you use for your power input.
If you ever find that one doesn't work, try plugging into the other one. If it then works, it's time to replace the automatic transfer switch.
— David
Old 02-16-2015, 12:42 PM   #3
2007 22' International CCD
Mast setups use the rear connection as priority over the front one. That prevents frying the generator with shore power. If shore power is connected the front generator plug is disconnected for safety. Sadly, my 2007 is not set up that way (yet)
Rich, building a nice list of improvements...
Old 02-16-2015, 01:49 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
New Lucy (2015 FC 25FB) came with the two separate 30 Amp connectors. There is one on the street side front, and another on the street side rear of the axles. We use the two connectors interchangeably, depending on the power situation where Lucy is camped or parked.
Since we got New Lucy on October 2, 2014, she has been plugged into shore power at least part of every day which is about 150 days. I would estimate that the we have used the front connection about half the time.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 02-17-2015, 11:17 AM   #5
Refugee from Napa, CA
Photobum's Avatar
Madison , South Dakota
My rear connector fried in Mexico and I have had to use the front connector ever since. I understand that it will be repaired under warranty and there might be an actual recall...
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 03-09-2015, 04:51 PM   #6
sequim , Washington
has anyone had the indicator light on the rear connection port burn out??
reelfastgreg is offline   Reply With Quote
Old 03-21-2015, 07:50 PM   #7
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
I too have had the status indicator light on one of the shore power connectors on my 2010 AS go out. I wonder if it is the status light itself, or that lack of light is indicating a fault of come kind. I'd love some opinions on this and on how to determine whether it is the one or the other.
brad1 is offline   Reply With Quote
Old 03-22-2015, 04:52 PM   #8
sequim , Washington
status lights in all sorts of things electrical 'usually' depend on a solid ground to operate. my first thought when the light went out on my rear connection port is maybe there was something to the recall regarding these connections.
as fate would have it, we were doing a road trip that took us past the AS dealer east of Seattle. they didn't test the ground connection, simply pulled the entire assembly off and put a new one on, warranty. they also did the propane tank recall at the same time. so now i don't know if that LED failed or if there was a ground wire problem.
to plug in or to not plug in...that is the questions 4hartungs Batteries, Univolts, Converters & Inverters 39 04-23-2014 03:44 PM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
