Old 01-18-2015, 11:57 AM   #1
1990 29' Excella
baltimore , Maryland
newbie and want to power up my TT
Hi All,
I just took delivery of a 1990 29 foot excella.
I want to power it up electrically from a 120 v extension cord.
What adaptor do I need?
Im not near the camper, but does it have a 220 volt 30A male
connector on it?
Also, this may not be the correct forum, but what other hookups
, hoses will I need for waste, clean water, etc.
THis will be in winter freezing conditions.
groundhogy
groundhogy is offline   Reply With Quote
Old 01-18-2015, 11:59 AM   #2
1990 29' Excella
Also, if it is a 220 vac connector, is that what this trailer really wants rather
than 110?
I assume there is a converter that takes the 120 or 220 vac and makes it into 12v dc.
Does the converter take either 220 or 120?
.... confused
Old 01-18-2015, 12:45 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums.
That's NOT a 220 connector. It is 110 volt/30 amp. DO NOT plug into 220. It will fry your camper!!!!
There is an adapter that you can buy at Wal-Mart to plug your camper into a regular 110 volt household out let. Plugged in to a 15 or 20 amp outlet, you can run most everything in the trailer wit the possible exception of the a/c.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 01-18-2015, 12:46 PM   #4
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
My guess is that is a 120 VAC 30 ampere system and cable. Be certain before you connect to power. I believe there was a recent thread where someone fried a bunch of their electrical system when they hooked to 220 VAC.
You'll need a dump hose to connect to sewer/septic dump, a potable water hose for filling the water tank. If the trailer has been winterized, you should treat the water system (Google it) to kill any critters. Get some toilet treatment to put in the black water tank. I recommend only hooking up hoses as needed, since you're in winter conditions. They can freeze. Run the furnace to keep tanks from freezing. An electric heater may not protect you. Have lots of propane, you'll probably need it. A surge protector would be a good idea, too.
Old 01-19-2015, 12:30 PM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is a 120 plug. All you need is a 30 amp to 20 amp adapter available at Walmart for $17. You can run everything in the trailer except the air conditioner plugged into a 20 amp receptacle.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-19-2015, 12:32 PM   #6
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Just so you don't miss it....... IT IS NOT A 220V PLUG!!!!
I have an adapter for mine to go from 110V outlet to the 110V 30A 3-prong plug.
Here are a couple of adapters:
https://www.etrailer.com/comparison....45&pc2=AR14365
110V 30 Amp Power Cord Adapter for camper Travel Trailer Pop Up RV Plug | eBay
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Dash Air Fan, Power window and Power Seat Stopped working alvinator Land Yacht/Legacy Motorhomes 3 07-13-2014 10:22 AM
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 06:18 PM
I want new Fantastic Fans but I dont want to give up the lights. memgrove2000 Roof Vents, Skylights & Fans 4 03-10-2009 10:21 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 09:23 AM
