Old 06-14-2011, 06:12 PM   #1
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
New wiring for trailer restoration
I'm ready to tackle the complete rewiring of my gutted 65 GT. I am considering running as much wire as possible inside the trailer in cabinet chases, conduit and such, as oppposed to between the skins. Wires to ceiling fixtures,fans,etc. would be fed under skin from junction boxes within cabinet/closets. I like the idea of being able to acces wiring without removing cabinetry and skins if a problem should arrise. Any thoughts or experince with this?
JLGT5107 is offline   Reply With Quote
Old 06-14-2011, 07:02 PM   #2
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
if you use 1/2 or even 3/4 inch plastic tubing.. ie pex-tubing, you can run it between the skins and you will be able to replace it any time. plan to have junction boxes / access points , where you have splices and locate those points within cabinets / behind sofa / bed.. wherever you can get to it.
this way , everything is service friendly as well as clean
submariner is offline   Reply With Quote
Old 06-14-2011, 07:34 PM   #3
1985 31' Excella
Fresno , Texas
If you run wiring in the cabinet areas you could have problems with possibly having wiring chewed on by little critters that might get in during non use storage. Are you wiring with the skin on or off?
Wsmith is offline   Reply With Quote
Old 06-14-2011, 09:24 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds good
I like your idea. It only makes sense to have everything accessible. I have added a few new things to our '74 and made sure that they are protected but easy to get to.
TG Twinkie is online now   Reply With Quote
Old 06-15-2011, 12:03 AM   #5
1985 31' Excella
Fresno , Texas
Thomas Betts 12008-100 PVC Flexible Ent Conduit
This is made to fit plastic junction boxes and is carried at the Box Stores in 10' lengths. It is very flexible.
The Buddha Baby A Restoration wasagachris 1960 - 1964 Sovereign 136 06-30-2012 08:56 AM
Does anyone have a wiring diagram for a '68 safari?...Please HolyRoller Batteries, Univolts, Converters & Inverters 1 05-11-2011 09:45 AM
Prodigy P3 Wiring - 2011 Silverado Ganglin Brakes & Brake Controllers 0 04-17-2011 09:46 PM
nagging wiring question DanielB 1973-1974 Excella 500 4 03-19-2011 06:00 AM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
