Well. Me and the wife put the body back on the frame of our 67 caravel.
We have aluminum wire throughout the trailer and want to replace it.
My question is, What is the very best type of wire to use for the 12 volt systems and what is the best type of wire to use for the 120 volt outlets.
Thanks for any help.
Eric and Elizabeth.
North Vancouver.
For 120v AC, I use MC Lite. It is aluminum metal armoured cable. It is solid conductor, not stranded. It has an insulated ground wire, the metal jacket is not the ground path. Comes in 25' rolls at HD or Menards, fairly inexpensive.
For the 12V stuff, I use THHN stranded, inside corrugated plastic conduit (usually called Smurf Tube).
I found that working with high temp vehicle wire materials and standard "Romex" type cable was quite easy and quick. It is what the factory uses, and has used for many years.
The yellow cables in the picture is for 120V wiring.
All the other colors are 12V supply lines in various gauges, for different uses.
It all originates from 2 fuse boxes, one for 120V fed by the shore power cord, and one for 12V fed by the converter charger and the battery bank.
I believe when my husband redid (completely) the wiring in our 1963 Bambi he also used romex... he has a number of entries on his thread about it, but it jumps around a bit, you might need to read through "chatter" to find it. I think most of it started around page 15. If you have time you might check it out: http://www.airforums.com/forum...-17925-11.html
Good luck. I was very happy he rewired our trailer. The original was very substandard and about 2 outlets in the whole thing!
copper wire is by far the best conductor of electricity .I use muti strand copper insulated wiring .the best starter solenoids ,coils ,electric motors , etc,all use copper windings and the maximum wire wrap.the best battery cables use muti strand copper wire ,the more strands the better flow of
current ,less amperage draw thru the wire or cable.solder all connections
where possible .
One of the top of the line wires is M22759 mil spec wire. It is teflon insulated silver coated stranded copper wire. It is also flame proof. It is also extremely expensive. Any stranded wire is better then solid wire, it is more flexible, and disipates heat faster then solid. Twisted multi-conducter cable is also better then wires that run parallal to each other in a common cable like romax. A cable that has an insulated ground it better yet and if the cable is sheilded its even better. These are the basic types, so take your pick for your needs. The materail used for the conducter from worst to best are 1) Aluminum, 2)copper, 3) silver, 4) gold. I know I left some gaps here but these are the most common. You cannot go wrong with copper
