Old 06-09-2010, 09:03 AM   #1
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
new umbilical cord
The trailer I just purchased (89 Excella) is in need of a new umbilical cord. The old one looks like it was drug on the ground and with lots of electrical tape "fixes".
Looking for a recommendation here:
  1. Is it worthwhile to make a removable umbilical cord or just replace the existing hard wired cord?
  2. I was thinking about making a bracket to mount under center of the trailer frame and mount a female 7 blade receptacle and get a coiled umbilical cord as seen here: RVUpgradeStore - 7 Way Round(RV style connector) to 7 Way Round(RV style connector) With 5' Coiled Electrical Cable
  3. Should I take the extra time and make a hole in the front of the trailer for the female receptacle?
  4. Is is worthwhile to have round pins on the umbilical cord - my forum search shows there is a wide variety of opinions on this topic.
Thanks for your help - Steve
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-09-2010, 09:10 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Crispy,
Have you seen this post by Bob Fowler...
http://www.airforums.com/forums/f447...lem-64886.html
If I were in your shoes I would do what Bob did. But then again that's just my opinion.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 06-09-2010, 09:21 AM   #3
crispyboy's Avatar
1994 30' Excella
That is essentially the idea that I was thinking about but I need to mount the receptacle closer to the frame because the original cable was damaged closer to the trailer.
Bob has a good idea - thanks.
WBCCI # 3072
Old 06-09-2010, 09:37 AM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I REALLY like the idea of this solution to the umbilical problem ... but it seems to me that there is one issue: if you were at a rest area and a vandal decided to walk off with your umbilical cord, he/she could do so and you'd be up the creek. The "usual" umbilical style is not so easily removable ...
AirsDream is offline   Reply With Quote
Old 06-09-2010, 02:30 PM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Factory Parts
The trailer I just purchased (89 Excella) is in need of a new umbilical cord. I was thinking about making a bracket to mount under center of the trailer frame and mount a female 7 blade receptacle and get a coiled umbilical cord...Should I take the extra time and make a hole in the front of the trailer for the female receptacle...Is is worthwhile to have round pins on the umbilical cord - my forum search shows there is a wide variety of opinions on this topic.
On the '78 year model, the umbilical was removeable from the factory.
See Electrical Wiring and Front Photo below...
The interior terminations are in the lower left hand third of the last pic.
On the Round Pin question - I occasionally experience problems, but a shot of WD-40 usually solves any open circuit anomaly.
You may be able to get all of the necessary parts off of a salvage unit.
Name:	CH 8 Electrical page (3).jpg
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-09-2010, 06:33 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
WOW !
Someone who actually used WD-40 for it's designed and intended purpose....... BRILLIANT!
Old 06-09-2010, 07:59 PM   #7
AirsDream's Avatar
1999 23' Safari
It doesn't say that he was using it to displace water ... maybe just rinsing away "crud."
Umbilical Cord Replacement watt1968 Electrical - Systems, Generators, Batteries & Solar 5 06-13-2009 06:39 AM
Umbilical cord/battery draw davidz71 Electrical - Systems, Generators, Batteries & Solar 5 06-16-2008 10:33 PM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 09:02 PM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 10:25 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 11:37 AM
