05-11-2016, 04:57 PM
2015 Interstate Ext. Coach
Miami springs
New purchase failing miserably 24 hours into our 1 trip (our anniversary)
We purchased our 2015 interstate ext airstream yesterday, on our trip the following day with our purchase and about 300 miles into the drive we ran into trouble. When trying to turn the generator on, it suddenly just clicked and nothing happened. Slowly, our navigation system started blinking, then slowly disappeared. Our battery disconnect also started flashing red. None of our lights worked. At this point, we have no idea what is going on, as we are newbies at airstream/RV in general. From one of your forums, I was able to see that if the battery is too low, the generator will not turn on. The car was running and our batter not charging. Can anyone help with that?
Question 2: why do you think this was not caught on the PDA?
Question 3: 30 minutes after this happened, our Ac stopped blowing cold air and continued to make the noise as if it was blowing, but no air coming out.
This was our one year anniversary. My husband worked so hard to make it special. Instead, we feel we have been completely misguided and ripped off. We are now in southwest Virginia and in despair. Any insight would help from anyone.
05-11-2016, 05:17 PM
2019 27' Flying Cloud
Kansas City
, Missouri
So sorry to hear about your problems!
I can offer a welcome to the AS forums and AS life, and sympathy.
And maybe some perspective in that I would expect that spending the night in your new rig, even with nothing but candle light, will be an occasion to remember. (perhaps not fondly, but memorable nonetheless).
Can you make your way to a campground with electric hookups? I am no Interstate expert, as I have a trailer. But I would imagine that by plugging into shore power your rig may be able to run the AC, etc.
If not, then maybe it's one of those "that's why we have a credit card" moments to get a hotel and dinner out.
Piggy Bank
05-11-2016, 05:25 PM
2004 30' Classic Slideout
Fenton
, Missouri
One question you can answer for us if whether the Interstate is brand new or whether it is used. Either way I'm assuming that there is some Airstream original warranty left. Is there an Airstream dealer either close by or within reasonable driving distance? If there is an Airstream warranty still active on your Interstate, you should be able to get it checked out, albeit not without requiring you some modification of your trip plans.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
05-11-2016, 05:30 PM
2012 27' Flying Cloud
W
, New England
First and foremost - I'm sure I'm with anyone else reading your post - just so sorry for the bad experience.
Did your purchase come with Coach Net? Do you have AAA or Good Sams? If so, perhaps a tow to a camp ground with power would help get through a few days anyway where you can strategize what to repair/replace.
It can't possibly feel this way right now, but to quote the pretty smart Bruce Springsteen - "...someday we'll look back on this and it will all seem funny..."
Until then - best of luck, give each other big hugs and welcome to the forums!
05-11-2016, 05:47 PM
1984 34' International
Toronto
, Ontario
Is the engine running ok? I am asking to figure out of the alternator is working ok.
05-11-2016, 06:11 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
There are several possible reasons for this, including low oil in the generator, but your litany of other problems does make it likely the house batteries are too dead to start the generator.
While the key was turned on and engine was running? The Kenwood/Garmin head unit should be wired up through a relay that provides power from either the starting battery or the house batteries. If the unit blanked out with the engine off, that's house batteries again, but if it blacked out with the engine running that could be a problem with the engine alternator not providing charging current. If so, that's a Mercedes Benz problem, not an Airstream problem.
Does that include headlights and dome light, or just "house" lights? Important because "house" lights draw current from the house batteries, but headlights draw current from the chassis battery and engine alternator.
I assume you mean the dashboard A/C because the rooftop A/C only runs on shore power and generator power. If so, that's another indication that it could be a bad alternator.
Trying to troubleshoot long-distance by description only is not easy. But since your litany of electrical failures seems to also include Mercedes Benz systems and not just Airstream systems, going to an MB/Sprinter dealer to have them check out the alternator would be a wise first move. If that has failed and your starting battery is also running low, you could be looking at getting towed when the engine fails to start next time.
And if it was the alternator, then going straight from the MB/Sprinter dealer to a campground with shore power connections to recharge your house batteries would be the next step.
The timing of your difficulties, occurring at the same time as your anniversary, probably makes an already bad situation seem worse. But on the bright side, you'll have a great story to tell your kids and grandkids later! After all, the only functional difference between a disaster and an adventure is how you tell the story when it's all over. Gripe about it and it's a disaster. Laugh about it and it's an adventure.
05-11-2016, 06:16 PM
From All Over
Engine is diesel, but has an electric fuel pump, so it would keep running— for a while— on the starting battery because at least the electric pump doesn't draw as much power as do spark plugs. But the starting battery will eventually get depleted as well.
I'm in agreement that it sounds as if the alternator or the voltage regulator built into it could be faulty.
05-11-2016, 06:19 PM
2013 27' FB International
El Dorado Hills
If its a alternator failure shouldn't a dummy light on the dashboard should have alerted the driver?
My alternator failed on my truck last fall and the dummy light is what alerted me. The remaining battery charge gave me about 50 miles, barely enough to reach a dealer for repairs.
05-11-2016, 06:26 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
I don't have an interstate, but I do have both class C and B motorhomes, and have had both an Airstream 325 and B-190 van, so I'll offer some generic things to check.
All is not lost, so don't despair... but you'll need to take a logical approach to troubleshooting exactly what's going on.
First, did you have any dash trouble indicator lights on? Was there any indication that you were having any issues with the starting battery, or the van's 12v charging system?
Next,most motorhomes have two separate 12v electric systems in the coach. One is the 12v van system that runs the engine, headlights, and the chassis. The other is the 12v coach system that is installed and runs the living quarters. There is likely a master "on-off" switch for the coach system. When it's in the off position, it keeps the battery from draining when the coach is sitting idle because of all the sensors and other electronics that draw current. The coach system is charged by both the van's 12v alternator, the 110vAC shore power converter system, and the generator when it runs; however if that master switch is off, the van's alternator can't charge the coach battery, and if the coach battery is low, it will all just go dark.
So, you mention that your nav system faded out. Is it in-dash or is it an after-market unit that you had plugged into the coach battery system? Will the van's engine start after it's shut off? If the nav was plugged into the in-dash, van 12v system, and the van won't start, then the alternator has issues and needs warranty work by Mercedes.
If, OTOH,if the van chassis is fine and it's just the coach that's not getting 12v, it could be the master switch, or a breaker or fuse. First, start the van's engine and then turn the master switch on. You should have lights in the coach. If that doesn't work, plug the coach into 110vAC and see if your lights work and the battery charges. If it all works when you're plugged into AC, and the switch was off, just turn it on, and it'll charge off the engine going down the road. If however, it doesn't work on 110vAC you have issues that need to go to an Airstream dealer to resolve.
Last, with the generator, if the coach battery is seriously discharged, and the master switch was off, it may take a few minutes of charging with the master switch on and the engine running before the generator will turn over... and that again depends on the brand and size of generator you have.
Good luck and let us know what you figure out! Welcome to the forums and welcome to Airstream ownership!
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
05-11-2016, 06:32 PM
2005 30' Classic
Burlington
, Ontario
I'm not familiar with the Interstate, so cannot offer much help - but I do believe that your problems will soon be resolved if you can get to a competent RV shop, and that you will go on to enjoy many happy years of RV'ing and be able to look back upon this first trip with a sense of humour!
Best wishes ............. Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
From All Over
One would think so, but if we're looking for a single root cause for all of the reported failures, it's hard to imagine anything else that could be at fault.
The alternative would be multiple concurrent unrelated failures. Which is theoretically possible, but impossible to troubleshoot until at least one root cause is fixed and we see which problems weren't solved by the fix.
And because an alternator failure would eventually leave the OP stranded and in need of a tow, while most other possible causes of individual system failures wouldn't, best to assume the worst for now, at least until an eyes-on hands-on examination tells the OP otherwise. If a system failure can get the OP into worse trouble— such as the engine suddenly quitting on the road— I can't in good conscience suggest checking anything else first.
05-11-2016, 06:34 PM
Salem
, Oregon
Not what you want to hear but.......
Hi, as someone who started working at new car dealers since 1968, it still amazes me that people will buy a car, truck, trailer Etc. and take that cross country trip the next day.
Buy the vehicle, take it home, read the owner's manual, try everything out, drive it around, get the feel of it, ask the dealer for help on things that you don't understand or about things that you think aren't working. Stay close to home until you understand what you bought.
Now start by going on short trips. Longer trips when you are somewhat experienced.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
05-11-2016, 07:30 PM
2004 22' Interstate
Tipton
, Iowa
While I'd agree that in a perfect world, this is good advice, Bob... it's singularly unhelpful for the OP in this thread. And, as someone who has gone great distances to buy motorhomes and drive them home, it's not always practical advice either. My '85 Airstream 325 was 600 miles away when I bought it. The B-190 was 400 miles away, and so was the Coachmen B-van I have now. Motorhomes aren't like cars. Sometimes the one you want is further away than your local dealer. You just have to be prepared for exigencies.
05-12-2016, 01:17 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
look and see if the alternator belt is still there.
Ricky
05-12-2016, 04:05 AM
Retired.
, At Large
I remember one of these Interstates showing up a couple of years ago with a b ad accessory fuse. It was located in a second fuse compartment under one of the front seats, and would allow the alternator to keep the battery charged, but about half the electronic things wouldn't wotk. Among the things that didn't work were the isolation switch between the truck and house batteries, and some Airstream-installed items.
05-12-2016, 04:36 AM
Normal
You need to find an RV dealership and take your new rig in to have these problems assessed and resolved.
Maggie
05-12-2016, 06:35 AM
texas
I can remember many times in the past that something was not going as planned. I would tell my wife, Honey, someday we will laugh at this. Her response was usually, that may be true but it will not be any time soon. Good thing is you are safe and together. Someday you will laugh about this. May all your experiences with your Interstate be good ones in the future.
If you are reading this, it means I have made it another day!!!
05-12-2016, 07:12 AM
1976 27' Overlander
Missoula
, Montana
Until the OP gives us a few more clues we can only speculate. But this thread on the Interstates and battery issues may be a clue. A close friend posted his experiences here: see http://www.airforums.com/forums/f240/13-interstate-batteries-toast-119386.html
In essence, the batteries deteriorate and go bad if the Interstate has been sitting on the dealer's lot. It the OP has a 2015 and it sat on the lot until a few days ago, when the OP took delivery, the batteries may be toast. Lots of frustration with this issue on the Interstate threads.
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
05-12-2016, 07:27 AM
Mantua
, Ohio
First thing should have been to call the dealer. They may have been able to help immediately. I would call now, see what they say? Good luck
05-12-2016, 08:10 AM
As others have said more info is needed. But, years ago when we bought our 1999 Cutter diesel single slide 35 ft Airstream Class A, we had a plethora of strange electrical events. Purchasing 12/99, the dealer had taken delivery 7 months earlier.
While parked on lot inventory, the "house" electrical system was never shut off. So, from our purchase date, the "house batteries" were trashed from get-go. The dealer fought vigorously against our insistence on them replacing the house batteries, even accusing us of swapping them out with dead ones. Needless to say, we prevailed, and with new set of deep cycles, our electrical problems were remedied, but we never went back to that airstream dealer
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
