Old 03-31-2012, 02:50 PM   #1
crane422's Avatar
1978 23' Safari
Columbia , Illinois
new led lights
OK so I bought new LED exterior lights and they have connector and obviously old lights just wired.. do I snip connector off and just splice new light wire onto original wire?
ID:	154710   Click image for larger version
crane422 is offline   Reply With Quote
Old 03-31-2012, 02:56 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Lights need both power AND grounding, and pictures don't show ground wire in old lights. Possibly metal housing screwed to metal frame considered ground, but seems like there should have been double wires coming into old fixture.. Looks like new fixtures also have just metal tab to ground to mounting surface... (Only single wire with billet connector shows in picture..) Splicing wires together is right answer, with water-tight connection, but you'll need to make sure both positive and negative (grounding) are connected for lights to work...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 03-31-2012, 03:53 PM   #3
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
given that you have only one wire from the new light, it’s probably fair to presume that your new light is self grounding by a screw through one of the two mounting holes.
if I was doing this, I’d first pull the black grommet out of the skin and see if I found a splice in the existing wire, which I’d then cut away.
then I’d clip the plug off the new light, slide that grommet onto the black wire, and then connect the new light with one of these connectors - SolderGrip Heat-Shrink/Solder Multiple Wire Butt Splices, 22-18, 15/Clam-CPGI-CWT-9002-15 at The Home Depot
(they also come in larger sizes for 16-14 and 12-10 wire)
then I’d stuff the splice back into the skin, closing the hole with the grommet, and screw the light down.
am curious to ask what manufacturer & part number of the lights you’re using. please also let us know how they look when done?
thanks!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
New Air conditioner advice? marzboy Furnaces, Heaters, Fireplaces & Air Conditioning 92 07-26-2012 10:41 AM
New member from Arizona Yuma Pav Member Introductions 13 05-15-2012 05:10 PM
New Member alfaguyair Member Introductions 8 03-31-2012 04:47 PM
New tires for 1979 Sovereign Lexgirl Tires 1 03-30-2012 10:27 AM
2011 Airstream Bambi 22' Sport Travel Trailer Simply Like New In Every Way! eBay Watch Airstreams on eBay 0 03-29-2012 03:00 PM
