Old 09-04-2019, 05:54 PM   #1
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
NEW Honda EU2200
Look what I just got! Brand new Honda EU2200.
Best part of all is Saturday I’m going to GUT IT! Yep going to do the Genconnex propane upgrade. This puppy will never see a drop of gasoline.
Of course the will be a full write up and Blog post to Follow
Caught this one at Home Depot before they added the $40 price increase Honda implemented to all EU gensets yesterday.
Old 09-04-2019, 06:17 PM   #2
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Was SO bummed, they came out with the 2200 just a few months after I got my 2000. I immediately did the Genconnex conversion too, and got both hoses from Genconnex...one, for the trailer port, and a regulated one for a propane bottle, I carry a 20# tank so I can locate the generator as far from the trailer at the rear as my electric cord will allow rather than have it right outside the dinette.
Ronnie, if you haven't asked them to yet, make sure you have Genconnex provide the high altitude jets, they'll do so for free. Stock jet is up to 5,000 feet, another for 5-8,000 feet, and one for over 8,000 feet. They change out in just a minute using an allen wrench that's provided. You're going to be at nearly 7,000 feet in Coulter Bay and W. Yellowstone, and surely using your furnace. Based on the sun and the shade for your solar...you'll likely be pulling this puppy out to recharge unless you have hookups.
pcskier is offline   Reply With Quote
Old 09-04-2019, 06:21 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
No need for the furnace, it's not below 32F ..... yet ....
Old 09-04-2019, 06:24 PM   #4
pcskier's Avatar
Park City , Utah
Hi
Bob they're from Alabama...not sure they have your Pennsylvania-thick blood!
Old 09-04-2019, 07:15 PM   #5
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
No! Use the Hutch Mountain Kit, dual fuel.
sheriff1 is online now   Reply With Quote
Old 09-04-2019, 07:56 PM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Peter thanks. Yes they sent me the extra jets. I bought this generator just for this trip. We are pretty excited to say the least.
Old 09-04-2019, 08:04 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Correct!
Old 09-04-2019, 08:13 PM   #8
Portland , Oregon
Yep, I'll bet they'll use the furnace to take the chill off in the mornings!
Wish I were heading to the Yellowstone area. My Brother-in-Law is there now with his Trailer and the fly fishing reports are making me very jealous.
Have a fine trip Ronnie.
P.S. Ronnie, I know you're busy, but check your PM inbox.
Cheers,
Bryan
blacklab is offline   Reply With Quote
Old 09-05-2019, 08:34 AM   #9
Half a Rivet Short
Hi
If we are on shore power, we run the Alde at night. Much nicer to get up to a livable trailer than bundle into heavy stuff just to make breakfast. That's been true pretty much all summer. We've had a lot of lows in the 40's and low 50's.
Old 09-07-2019, 03:47 PM   #10
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Genconnex install
What a super fun project. Easy to do and smooth as silk. Honda cranked right up on the 3rd pull. Purred like a kitten.
Here are a few pics form the install.
ID:	351584   Click image for larger version
ID:	351586   Click image for larger version
ID:	351588   Click image for larger version
ID:	351590   Click image for larger version
ID:	351592   Click image for larger version
Old 09-08-2019, 05:11 AM   #11
Long Island , New York
Thanks for the details and photos. This will be our next purchase if we are heading into hot weather. Our tri-fuel Yamaha 1000 is so portable and easy to use, especially with the BBQ hookup in addition to the quick-connect on the AS. Won't run the A/C of course. Do you have the EZ Start or [similar] add-on?
Peter
Old 09-08-2019, 05:44 AM   #12
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Peter, I think you already know that you won't run A/C on anything less than a 3KW generator, unless you install an Easy Start. Then you can run A/C on a 2k generator with some other constraints. As a reminder, they found that even some brands of 2k generators would not work with the Easy Start because the Honda actually held voltage up longer. The 2.2kw generators may well have solved that issue, though.
Larry
lsbrodsky is online now   Reply With Quote
Old 09-08-2019, 05:47 AM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Admittedly it has been a few years, but when I converted my Yamaha to propane, it required running the engine on gasoline for a certain number of hours before doing the conversion. This was to ensure proper break-in of the engine.
It would be worth checking in it is required in your case.
2019 Ford Expedition Platinum
Old 09-08-2019, 05:52 AM   #14
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Peter
Peter,
Yes I have a MicroAir EasySTART installed on my 15K AC. I’ve been able to run it on an old Honda eu2000i (gas).
Yesterday I was able to run the A/C with the New EU2200i on propane. With no trouble. Measured amp load at the Generator at 14.8amps output voltage was 119VAC
I did not run the AC but for about 10min on the new Generator (Brake-in). The load and voltage was steady.
Old 09-08-2019, 07:38 AM   #15
mandolindave's Avatar
Actually...
Larry
The Honda 2200 runs my 11K BTU air conditioner, without the easy start. I don't know if I had to, but I turned EVERYTHING else off. I will be installing the easy start soon though.
mandolindave is offline   Reply With Quote
Old 09-08-2019, 08:11 AM   #16
1989 32' Excella
Sharon Springs , New York
Just curious, how long will the Honda 2000 or 2200 genset run on a 20lb l.p. tank? We have 2x Honda 2000 gensets (companion set) we used for a/c ops before installing the e-z start system. Looking at converting one to l.p. leaving the other gas for flexibility sake. Also, what is the most user friendly l.p. conversion system folks have found? Thank you in advance, Jim and Gretchen
MAJORJDB is offline   Reply With Quote
Old 09-08-2019, 09:16 AM   #17
GSansoucie's Avatar
2019 28' Flying Cloud
South Berwick , Maine
This is what I’m doing with our new EU2200i that we just bought from TDH yesterday (with our Veteran’s 10% discount). While I don’t plan to run this on gasoline, I don’t want to limit myself to propane only, should the need arise at some point in the future. The fact that the kit takes about 30 min to install helps too.
GSansoucie is offline   Reply With Quote
Old 09-08-2019, 10:23 AM   #18
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
Just want point out that the high altitude jets help only with fuel efficiency and keeping the generator running smoothly. Carburetor jets will not overcome the power loss at altitude. Also, running high altitude jets below 4000 ft will cause a lean condition that can damage the engine.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 09-08-2019, 02:16 PM   #19
Thanks for all the recent comments.
Peter
Old 09-09-2019, 08:43 AM   #20
skitger's Avatar
2018 16' Sport
Corvallis , Oregon
pcskier and Ronnie, Thanks for the comment on the high elevation jet! I just had Gary at GenConneX send me one, they are great. I love my GenConneX 2200. I also got it for the Yellowstone trip, but totally forgot about the elevation and generator, looks to be in the 30's at night, so I will be running the furnace! I hope to see you folks up there, Thanks
Rick & Paula LaMont
2018 Sport 16’
WBCCI #7944
skitger is offline   Reply With Quote
Honda EU2200 + Victron MultiPlus = No A.C.??? JonSchroeder Generators & Solar Power 7 09-05-2019 09:42 AM
Honda EU2200, Propane, Gas, Easy Start load testing ghaynes755 Generators & Solar Power 6 09-05-2019 08:33 AM
Honda Eu2200 runs Air Conditioner rp709 Generators & Solar Power 1 10-10-2018 01:49 AM
Honda EU2000 x 2 vs Honda EU3000 and Yamaha 3000 IntegrityAir Generators & Solar Power 43 07-01-2009 11:19 AM
Honda EU 3000 vs 2x Honda EU 2000 vajeep Generators & Solar Power 93 07-23-2008 11:02 AM
