Old 09-23-2015, 12:26 PM   #1
2015 25' FB Flying Cloud
Sandy , Utah
New Flying Cloud 25 Furnace question
So far I have not needed it, but as colder temps are coming ,does the furnace run on battery power if AC unavailable?
rocco52 is offline   Reply With Quote
Old 09-23-2015, 12:51 PM   #2
Stream'n's Avatar
2014 27' Flying Cloud
Lexington , Oklahoma
Yes, your furnace fan will runs off battery power when not plugged into shore power. However, if it gets really cold and runs a lot during the night it will deplete the batteries, so you'll need a generator to replenish batteries in the morning.
Stream'n is online now   Reply With Quote
Old 09-23-2015, 01:12 PM   #3
Sandy , Utah
Thank you!
Old 09-29-2015, 07:14 AM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
FYI, if you deplete your batteries by running your furnace overnight, it may also affect your water pump, refrigerator and anything else that uses 12-volts for control purposes.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 09-29-2015, 07:57 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If you deplete your batteries below 12v you will shorten the life and the capacity. Purchase a multimeter to check the voltage at the batteries. You have a SeeLevel monitor panel. I looked up a SeeLevel document and it should show the volts. You can compare that with the multimeter reading from the batteries. If there is a load on the 12v system there may be a difference between what the SeeLevel shows and a multimeter testing right off the battery posts.
Kelvin
Old 09-29-2015, 08:21 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Don't forget to turn the furnace's thermostat to a lower temperature or completely off while traveling. I've forgotten this a few times and used up a lot of propane.
Also, you do not want the fridge or furnace running on propane while at a fuel stop.
Alan
Flying Cloud :: 1958 Airstream Flying Cloud Cloud58 Airstream Registry Discussions 0 08-19-2011 08:32 AM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-11-2010 03:40 PM
2010 Airstream Flying Cloud LIKE NEW!!!!! S2010 Airstream Flying Cloud LIKE NEW!!!! eBay Watch Airstreams on eBay 0 11-04-2010 03:40 PM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
