Old 10-20-2018, 09:10 PM   #1
Starstream's Avatar
Spring , Texas
New Electrical with Battle Born Batteries
This will be a multi section post of the new electrical system. The first part will be the build, the second is testing and the third will be performance.
The planning of this project started a few years ago with a huge goal in mind—being able to run any device in the trailer using lithium batteries and solar with minimal shore/generator power. Of course, any good project starts by doing a lot of research. Mine consisted of internet searches of the various companies and watching numerous hours of YouTube videos. Seeing what others have done—what they liked, didn’t like and what I liked or didn’t like, and seeing what might be improved upon. I also private messaged several on the Airforum, emailed the authors of the YouTube videos, and called different companies. So, when the first post about Battle Born Batteries showed up on the Airforum, I was intrigued with the possibility of a lithium “drop-in” replacement for our AGM.
I sent an inquiry to Battle Born via their web site and within a couple of hours was contacted by Sean Nichols. One of the first things I explained to Mr. Nichols was how I would have to piecemeal the components over time as money became available. After several email and phone call exchanges with Mr. Nichols and Dr. Denis Phares, we came up with a plan. A complete re-do of all the electrical. And after several more email and phone calls with them about the build, it was time to place the first order.
Ordering items for this build took about 2 years.
The following was ordered from Battle Born
1) 4 X 100-amp hour Battle Born Batteries
2) Victron 150/60 MPPT
3) Victron Multiplus 3000
4) Victron Color Control GX
5) Victron BMV 700 battery monitor
6) VE direct cables X 2
7) VE direct dongle
8) MK3 interface
This is the list of other items ordered
1) 4/0 cable and lugs
2) 2/0 cable and lugs
3) #2 cable and lugs
4) #4 cable and lugs
5) Heat Shrink Tube
6) Cable Lug Crimper
7) Different size In-Line Breakers
8) 100-watt solar panel X 4 (so far)
9) 3 X Bus Bar
10) Shorter RJ-45 cables
11) Class T Block and Fuse
12) Battery Master Switch
13) Battery Bolt Set
14) Victron Monitor Box
15) 50amp WFPO Power Center
16) 30amp Smart Plug kit
17) Various wire crimps
18) Radiant Barrier roll
19) Cooling Fans with controller and thermometer
20) Micro-Air EasyStart
21) Plus, a bunch of miscellaneous stuff that I didn’t foresee—cable ties, flexible tubing to hold wires, 3m VHB tape, hinges, screws, nuts, bolts, washers, scrap wood etc.…
The different orders from Battle Born went smoothly and all items were received as expected. In particular the batteries were extremely well protected and packaged. I will note that the second set of batteries ordered did come with the nuts, bolts and washers, which is standard now.
This is the rough sketch of the build
When we purchased the ’79, the 12-volt fuse system was located in the front and the 120 breakers were in the wardrobe closet. The main power cord was wired through and stored in the back bumper trunk. The previous owner removed the gaucho and closed off the battery compartments. They relocated the original Univolt to an outside enclosed box on the tongue behind the propane tanks and strapped a single plastic battery box on top of the Univolt.
The front at time of our purchase.
The 12-volt wiring after removing the front panels.
The front with temp wiring. We traveled with temp wiring for 2 years while we gathered enough items to start the build.
Starstream is offline   Reply With Quote
Old 10-20-2018, 09:20 PM   #2
Starstream's Avatar
Spring , Texas
The start of the new electrical front. Installed Smart Plug shore power and reflective insulation and batt insulation. Next a vapor barrier with taped seams. Finally, the assembly board where the majority of the components were mounted and the rack with a shelf for the rest of the components.
One master switch with both positive and negative cables. One in-line circuit breaker that cuts off the power from the 7-way. One master in-line circuit breaker from the MPPT solar controller.
Some of the in-line circuit breakers are slightly modified with a breaker box lug connector to accommodate the larger cable size.
With the new face frame and intake cooling fan on the bottom. The cooling fan isS mounted to 1/4-inch plywood and can be slid either to the right or left, allowing full access to the batteries. Also added 1/8-inch neoprene under the batteries to help cushion and keep them in place.
Old 10-20-2018, 09:33 PM   #3
Starstream's Avatar
Spring , Texas
With the new power center and Victron Color Control. Shore power went first to the 30-amp breaker located in the center of the distribution panel, and a second 30-amp breaker completes the circuit to the Victron Multiplus. From the Victron Multiplus, power returns to the Main 30-amp section on the left and distributed to all 120-volt components. The open area on the right side of the power center is for the 12-volt blade fuses.
Master cut off switch for the 12-volt blade fuse.
The MPPT solar controller. 2 solar arrays, each array is first connected to an in-line circuit breaker then combined to another in-line circuit breaker before being connected to the MPPT. This way one array can be taken off line at a time if work or maintenance is needed.
The Multiplus wired up. The extra RJ45 cable is for the Victron MK3 Interface.
All wired up.
Old 10-20-2018, 09:35 PM   #4
Starstream's Avatar
Spring , Texas
The front before adding the final touches. On the top in the center are ventilation grates, on each side are exhaust fans and just left of center is the thermal control for the fans. The left/right front face panels can be lifted out for easy access to all of the components.
The completed front with the original curtains dyed blue and the multi-color poured resin top.
Old 10-20-2018, 11:20 PM   #5
2012 Avenue Coach
Corpus Christi , Texas
Nice job! Very well documented.
rowiebowie is online now   Reply With Quote
Old 10-21-2018, 10:24 AM   #6
Starstream's Avatar
Spring , Texas
When I copied this from my word document I missed these paragraphs.....
I want to point out some things very unique about Battle Born as a company.
They are a USA company, which is very important to me. I am a 100% disabled veteran living on the VA fixed income. They understood my limitations both physically and financially. If I found any of the components they sell for a less expensive price, they price matched without any hesitation. They also provided me with a generous veteran's discount. This level of service is becoming more and more rare these days.
Old 10-21-2018, 10:25 AM   #7
Starstream's Avatar
Spring , Texas
Thank you
Old 10-21-2018, 10:38 AM   #8
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 71
Nicely done. Thanks for sharing.
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 10-21-2018, 04:23 PM   #9
2019 20' Flying Cloud
Eau Claire , Wisconsin
Great job, appreciated reading and seeing this project. Kudos to you, thanks for posting.
Backfortyjoe is offline   Reply With Quote
Old 10-21-2018, 05:55 PM   #10
2016 30' International
redondo beach , California
Crazy nice upgrade!
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 10-21-2018, 10:12 PM   #11
iaqstuff's Avatar
2013 Interstate Coach
Yarnell , Arizona
Battleborn is the greatest!
We LOVE our Battleborn batteries! And while their products are worthy of praise, their company ethics are really what we'd like to praise. It's difficult to find a corporate business deserving of praise in today's money-grabbing corporate world. Wish everyone were as honest and concerned about their customers as Battleborn is!
iaqstuff is offline   Reply With Quote
Old 10-22-2018, 09:05 PM   #12
Starstream's Avatar
Spring , Texas
I fully agree. After hours customer service is excellent as well. They have gone above and beyond all my expectations.
Old 10-22-2018, 09:08 PM   #13
Starstream's Avatar
Spring , Texas
Thank you
Old 10-22-2018, 09:09 PM   #14
Starstream's Avatar
Spring , Texas
Thank you
Battle Born LiFePO4 batteries fran&frank Batteries, Univolts, Converters & Inverters 340 09-27-2018 08:42 AM
Battle Born Warranty ROBERT CROSS Batteries, Univolts, Converters & Inverters 10 09-23-2018 09:14 AM
Word of warning for LiFePO4 battery conversions (Battle Born) SilverHouseDreams Batteries, Univolts, Converters & Inverters 136 09-08-2018 09:37 AM
New Batteries from Battle Born Photobum Batteries, Univolts, Converters & Inverters 9 04-14-2018 08:40 PM
