Old 03-28-2018, 01:24 PM   #1
1974 27' Overlander
Salt Spring Island , British Columbia
Lightbulb New Electrical System from Scratch - What do you think of this?
Hi all,
My partenr and I are doing a frame off, full gut renovation on a 1974 Overlander. We're building a custom interior and intend to live full time in our airstream with it parked in a single location.
Designing and instaling the electrical system has been the hardest part of the renovation for me. I'm a comitted DIY-er but I started this project with only limited electrical knowledge. The learning curve is steep!
When I started out I found diagrams of other people's electrical sustems really helpful so I'm sharing mine here too. I'd also love to hear some feedback on what I've put together. Fire away with any comments, suggestions, critques.
I should also give the disclaimer that I was learning as I assembled this system and there are a few minor things I would do differently if I could go back in time but im generally happy with how its come together.
The system is built around a GoPower IC2000 Inverter/Charger and a tiny battery (for the moment) because we are going to be hooked up to shore power most of the time. Our intention is to move off grid eventually so we've included flexibility to shift away from shore power in the future.
Inlet: Furrion 30A Valox
"Main Panel": Siemens 2/4 60A Loadcenter EQL260S
Inverter/Charger: GoPower IC2000 and GoPower DC Instal Kit GP-DC-KIT4
Battery Isolator Switch: BlueSeas M-Series 6006
DC Breaker: BlueSeas 285-Series 50Amp Surface Mount Breaker
DC Loadcenter: Basic 12V panel supplied by VTS
Cheers!
File Type: pdf Final Airstream Electrical Diagram_2.pdf (50.0 KB, 49 views)
canadianair is offline   Reply With Quote
Old 03-29-2018, 08:10 AM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Nice job. I would consider adding a hardwired Progressive EMS ahead of your inverter/charger. Worth it to protect your electrical system against surges, miswired outlets, high/low voltage, etc.
TheGreatleys is offline   Reply With Quote
Building Airstream From Scratch - What would you do? bass-o-matic Exterior Restoration Forum 45 02-11-2018 08:58 PM
New electrical from scratch micaso Electrical - Systems, Generators, Batteries & Solar 16 03-21-2016 06:39 PM
12v/120v System From Scratch bredlo Electrical - Systems, Generators, Batteries & Solar 6 06-17-2014 11:22 AM
Help ReDesigning my Electrical System from Scratch crabbey1 Electrical - Systems, Generators, Batteries & Solar 3 06-07-2013 02:51 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
