Old 09-12-2005, 08:12 PM   #1
New converter and batteries
Just had a WFCO 3 stage converter charger installed in our 03 Safari 25. Also had 2 6 volt AGMs installed in the battery compartment, huge increase in reserve capacity for camping/boondocking, waiting on the modified battery lid to finish the work. Had the good folks at Airstream of Spokane do the install, also had them do some interior panel repairs, they did a great job. I can't wait to get it back out on the road and find some nice quiet cg to park in. From what I'm reading the new converter should really whack a good charge on the batteries when I fire up the generator. Will post some pics of the battery box soon as it's done.
flsafari is offline   Reply With Quote
Old 09-17-2005, 05:21 PM   #2
2010 30' Classic
Portland , Oregon
Why did you have two 6v AGMs installed...
I too am looking for ways to increase my reserve capacity for boondocking.
Vince
2010 Classic 30
Portland, OR
vwilleford is offline   Reply With Quote
Old 09-17-2005, 05:38 PM   #3
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Pictures?
I would love to see a picture or two of your setup. Didn't your 25' have two batteries? Our 25' CCD has two and with solar panels (and the Honda 2000i) we do alright, but I'm going for AGMs when the originals get tired. -Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 09-17-2005, 07:30 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Two 6 volt batteries in series, is 12 volts. While cutting the available amperage in half, it effectively doubles the reserve capacity.
If you had two 12 volt batteries in parallel, you would have all the voltage, twice the amperage, and half the reserve. Since we don't need all that amperage in our trailers, we go for the length of time we can leave our lights on.
Old 09-17-2005, 08:17 PM   #5
2003 25' Safari
spokane , Washington
new charger and batteries
I put the 6 volt batteries in for the whopping increase in reserve capacity. if I'm not mistaken they are rated at 490 minutes with a constant 25 amp draw versus around 200 minutes for the 12 volt group 27 batts the factory installed.
I chose the AGM version for the speed that I can recharge them. Yeah they cost a little more but with the new converter/charger (3 stage) they really top off quick compared to the 12 volts being recharged by the single stage factory converter. Having spent a few nights out where my wife ran the furnace all night and killed the batts at three in the morning I figured there had to be a better way.
I should have some pics available next week, also hope to stop off at the CAT scale and check for any gross increases in tongue weight.
wasafari is offline   Reply With Quote
Old 09-17-2005, 08:18 PM   #6
2003 25' Safari
new log in
oops, sorry, we moved so I changed my log in from flsafari to wasafari......
Old 09-17-2005, 09:16 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
That's one fast move!
Great tow vehicle, eh?
5 meter Langford Nahanni
Old 09-18-2005, 05:45 AM   #8
1993 21' Sovereign
So, where did you mount the jet engine? On the trailer, or the tow vehicle?
I don't remember, do you have a solar panel installed on your coach, or are you just charging with shore power? Of course, in Seattle there are less sunny days than you had in Florida, so solar may not be as beneficial there.
Old 10-19-2005, 08:19 PM   #9
1970 23' Safari
Denton , Texas
Agm???
I know what volts are. I know what amps are. What is an AGM battery?
shannon is offline   Reply With Quote
Old 10-19-2005, 08:33 PM   #10
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Absorbed Glass Mat. The electrolyte is contained in a fiberglass like mat, instead of liquid between the plates. Optima batteries are good examples.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-20-2005, 06:52 AM   #11
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
This is incorrect. When you put two 6V batteries in series, you have twice the voltage, but only the amp-hours of a single battery. When you put two 12V batteries in parallel, you have twice the amp-hours of a single battery, but only the voltage of a single battery.
That being said, a single 6V battery typically has double the amp-hours of a single 12V battery, so either setup gives about the same amp-hours. For example, a Trojan 6V-AGM battery has 200AH. Two in series still have 200AH. A Group 27 size Trojan 27-AGM has 100AH. Two in parallel have 200AH.
The difference is that 6 volt golf cart batteries can be cycled more times to the same depth, or the same number of times to a deeper depth, or somewhere in between, over their entire life. OTOH, if one of two 6V batteries in series fails, the whole system is dead in the case of an open, or not much better than 10 volts in the case of a single shorted cell. In the case of two 12V batteries in parallel, the system is at 50% capacity in the case of an open. In the case of a shorted cell, the bad battery will pull the whole system down to not much better than 10 volts, however, you can remove the bad battery from the circuit, recharge the good one, and continue to operate at 50% capacity.
Maurice
Old 10-21-2005, 10:53 AM   #12
2002 25' Classic
Kalama , Washington
Battery compartment mod is necessary to accomodate the golfcart batteries. Once that is accomplished an additional benefit is realized...golf courses, hence golfcarts and their batteries are nearly EVERYWHERE. We've had ours 18mths added water just yesterday for the first time. We use a threestage charger (Intellipower) and installed a solar panel disconnect switch giving us complete control of where charging energy comes from. Looking forward to a long run from our battery bank but if needed, replacements will never be far away.
nwclassic is offline   Reply With Quote
Old 10-21-2005, 06:00 PM   #13
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
battery options...
after reading the options, i think i like the dual 12V option. i need to start thinking about the battery options in my trailer. a couple of questions...
if i use dual optima batteries, do i need to vent the battery compartment to the outside? or are they truly "sealed cells"? i do not fully understand the deep cycle stuff rither. i think one is good to start a car, vs one that runs longer (for RVs). if i went with the optima batteries, i believe those are the yellow ones? is 2 batteries the standard?
also, i have been thinking about powering a few electronic devices in the trailer (flat screen, computer, etc). i don't want to have to run them off 110, and since they all have power converters that change the voltage to either 12 or 18 volts DC, i think it would be better to drive them off some sort of power regulator that maintains a constant voltage, instead of fluctuating (especially for the computer). any thoughts? it would be great to ditch those ugly converter boxes, that's for sure!
jp
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 10-21-2005, 07:50 PM   #14
2001 34' Limited
The State of , Ohio
The Optimas are AGM batteries, and AGM batteries are truly sealed unless you grossly overcharge them. The problem with the Optimas is that their spiral wrapped "six-pack" design doesn't use all of the volume contained in the length x width x height and therefore they don't have nearly as much capacity as conventional form-factor AGMs like the Lifeline brand.
I have run any number of electronics that use a 120VAC to 12-14VDC "wall wart" directly from 12 volt batteries, usually with a cable from Radio Shack, both in the Airstream and on our boat. Some LCD TVs also use 12VDC power supplies.
This doesn't include notebook computers, and some LCD TVs, though, which need higher DC voltages. You can get inexpensive 12VDC adapters for notebooks at electronics stores, and even adapters from some OEMs such as Dell. But if you want a really good one, check out those made by Lind
Maurice
Old 10-21-2005, 08:58 PM   #15
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Moe,
Thanks for the link...I have been looking for the odd 12V DC to other DC voltage adaptor for a while.
Uwe
www.area63productions.com
Old 10-22-2005, 04:39 AM   #16
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
are you putting a computer in yours as well, uwe?
jp
Old 10-22-2005, 05:02 AM   #17
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
jp
I have a PowerBook G4 with DVD capability that I might want to bring and run on a 12V converter. We also have a 15" LCD TV that has a wall wart type power supply, but it wants to see 19VDC, not 12VDC. So in order to run that, I would need a 12Vdc to 19VDC adapter, as the ones mentioned by Moe.
I actually though about installing a Mac Mini somewhere under a counter, and using it as my entertainment/computer center. With DVD, TV adapter, Wifi Card, and bluetooth, wireless keyboard and mouse, one could have a very potent, but also very small entertainment system. The Mac Mini is also very quiet.
I am running 2 12V group 27 Interstate deep cycle batteries. I will still have to come up with a venting system for those, as they are inside the living space of the trailer.
I used the 12V system, basically from the day it was functional, for lights and to run the fantastic fans while construction of the interior was under way. The batteries have been very stable so far, even after many days of not running the Intellipower to charge them.
My converter ( Intellipower 60A with charge wizard) does an excellent job, btw. It is, however, not as quiet as I had hoped. It's cooling fan makes itself heard prominently, and often. The load on the system is usually about 140W, if I run all the lights and two fans on low. I believe that's about 11.6A if memory serves me right. Hopefully the noise will be dampened by the surrounding furnishings once the interior buildout is completed.
Uwe
Old 10-22-2005, 05:16 AM   #18
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Originally Posted by uwe
...I actually though about installing a Mac Mini somewhere under a counter, and using it as my entertainment/computer center. With DVD, TV adapter, Wifi Card, and bluetooth, wireless keyboard and mouse, one could have a very potent, but also very small entertainment system. The Mac Mini is also very quiet....
ha! you stole my thunder! that's exactly what i'm doing, with a 23" apple monitor mounted on a wall. i love the way the mini looks. VERY airstreamy! i'm not sure about it's power requirements, but the power adapter is bigger than the computer. once i get to that point, i think i'm going to try to run all the wires inside the walls (power, monitor, speakers, etc) with a subwoofer under the front couch. this RV's gonna be rockin, alright!
so, you're a mac guy, huh?
jp
Old 10-22-2005, 05:24 AM   #19
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
jp
Yes. My first computer was a Mac, and I am still using them today. I use several of them at my business on a small network, and this PowerBook at home and on the road. We had our share of PC's as well, sincemy wife works for Toshiba, but I always migrate back to the Mac. Once you had a Mac, you never go back.....
Sorry for taking this off topic.
Uwe
Old 04-30-2006, 04:04 PM   #20
2010 30' Classic
Portland , Oregon
Now that you have lived with your new battery/charger set-up for awhile, what do you think about it? Do you find that you have a noticeable increase in battery capacity when boondocking?
I have a 2004 Safari 25 and will be replacing my batteries soon so I need to decide what to do...
Vince
Portland, OR
Vince
2010 Classic 30
Portland, OR
Batteries Short...New Converter robandzoe Electrical - Systems, Generators, Batteries & Solar 25 03-22-2005 11:38 AM
???s about Batteries & Solar joossens Generators & Solar Power 6 06-01-2004 09:51 AM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
Battery lock Pahaska Our Community 8 11-23-2002 10:45 AM
Converter Breaker? Sav'h Steve Electrical - Systems, Generators, Batteries & Solar 7 11-18-2002 08:45 AM
