Old 03-27-2002, 10:29 PM   #1
New battery selector switch
Battery switch to control use and charging. The choises are both batteries, or one battery, or no batteries. Digital voltmeter used to monitor batteries condition.. Frank
Name:	battery selector switch.jpg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 02-04-2013, 10:47 PM   #2
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
All boats have these - to separate starting batt. from house batt. Keeps you from running down both and not being able to start engine. Can be purchased at any boat store. Not sure need on RV.
Silver Hawk is offline   Reply With Quote
Old 02-05-2013, 03:17 AM   #3
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Just a word of caution here.
This type of switch is prone to failure.
Burned and Bad 1-2-Both Switches
The link is to the Ample Power website.
David Smead the author has literally written the book on the subject of 12 volt power. He is one of the best. If you need a battery kill switch, consider one of these Hella switches as they are very reliable....
Accessories, Battery Switches, - Hella Marine
Just my 2 cents..
Bruce
Bruce B is offline   Reply With Quote
Old 02-05-2013, 08:48 AM   #4
1988 32' Excella
Robbinsville , New Jersey
Just my 2 cents..
Bruce
At least it's not nearly as bad in a trailer as in a boat, as in the article.
In a trailer unless using a large inverter you would normally not have more then 60 amps going through the switch, not the 150 amps in a boat and a modern converter can safely supply 12V without a battery in the system.
Old 02-05-2013, 09:00 AM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Minimize the load before switching batteries or battery banks and the switch will last as long as you and I.
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 02-05-2013, 12:24 PM   #6
Bruce B's Avatar
I tried to warn you!
Our current boat has three of these rotary switches and they are fine in 8 seasons of sailing but I have been lucky. I have experienced a couple of meltdowns in as many seasons (2) when the switches are never switched under any load and the loads are not that high in the first place.
I do not trust them....
I have replacements for the boat that I will install this year as I know I am pushing my luck. Makes me wonder if it is truly a design issue as Smead suggests or if it is a quality control issue. I will dissect the switches after I remove them just to see what is there....
Bruce
Old 02-08-2013, 06:34 PM   #7
mefly2's Avatar
Yes, please keep us posted. My experience is dated back a few years and quality control may have changed significantly from the switches on our 8 meter sailboat.
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 05:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
