Old 06-05-2009, 02:18 PM   #15
Petersburg , Virginia
Thanks so much for all the ideas!!
We have an electrician coming out this weekend, and I'll make sure to tell him what you said.
You're the best!
I'll update you on our progress next week...
BeckyAnt is offline   Reply With Quote
Old 06-11-2009, 03:39 PM   #16
Yep, we took the Univolt out and it is definitely dead. It was actually pretty scary looking--it should have had "FIRE HAZARD" painted all over it!
I was expecting it to be a pain to remove since it was under the oven, but all it took was removal of four screws on the oven, disconnecting the gas line and cutting two wires, and we were golden! (oh, and of course, two strapping guys to pull out the oven...)
We'll be replacing that Univolt VERY soon. Thanks again for all your advice!!
Old 06-11-2009, 03:51 PM   #17
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
You might want to save the fuse panel off the univolt, we did on the advice of others here and it made installing the new inverter much easier.
Annette
bullydogsmom is offline   Reply With Quote
Old 06-15-2009, 03:53 PM   #18
Thanks!! :)
We are really good at following instructions!
We have contacted Randy and ordered our new inverter and a new fuse panel!
We bought a 1974 Service Manual
AND
We are keeping the fuse box from the old Univolt as a precaution.
Thanks again to everyone...will let you know how it goes when we hook it all up!
electrical problem ALANSD Mechanics Corner - Engines, Transmission & More... 23 09-13-2015 07:20 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 6 08-03-2010 02:57 PM
greetings and electrical problem wdm1 Member Introductions 2 12-18-2006 02:02 PM
electrical problem David Hall Electrical - Systems, Generators, Batteries & Solar 7 12-31-2003 08:46 PM
electrical problem kent osborn 1966 - 1968 Safari 3 09-27-2003 05:30 AM
