Old 12-29-2015, 07:50 AM   #57
richw46's Avatar
Lexington , Kentucky
Originally Posted by PKI View Post
Dealer told us in a seminar that the use/store switch should go to store after a couple of hours so after the batteries were recharged, they would not continue to be fried by the charger. Of course this info was not in the orientation walk through discussion. The other interesting information is that the water does not seem to boil away. We have added water when we got the trailer (warning sign?) and small amounts twice since. Is loss of water not a prime indicator of overcharging? Or rather, can you be overcharging without observable loss of water? Pat
Loss of water means it's either overcharging or you have a dead cell in the battery and the charger is trying to get the battery to a charged state. It overcharges the other cells trying to get the dead cell charged.
If you're adding water then you should get a battery hydrometer. Go to your local parts store, Wal-Mart, etc. and look for one, they are usually cheap. Even a good one is not terribly expensive. Check the charge in each cell, they should all be about the same level but I'm betting one will show much lower than the others. If so, you need to replace the batteries.
If they are the same level then the converter is overcharging. You should replace the one that came with the AS with a multi-stage charger, like a Progressive Dynamics. If you're somewhat handy this is not a tough DIY project, just follow the instructions, starting with disconnecting the batteries and AC power.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 12-29-2015, 07:57 AM   #58
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I did the Progressive Dynamics replacement on our 2013 25FB International Serenity, I had to get creative to get nearly another two inches of wire pulled into the new box as one wire went to a post farther from the securing wire grommet at the edge of the new box.
We call this stretching the wire.
Old 12-29-2015, 08:12 AM   #59
lewster's Avatar
Naples, FL , Hood River, OR
There is a sufficient amount of the 6AWG cable that powers the fuse block, but it's behind the breaker box.
Remove the breaker panel from the wall, loosen the strain relief tax the back and pull your wire thru (should be red and white).
Re-tighten the strain relief, replace the breaker box and continue your conversion.
Airstream does provide sufficient slack for an appropriate 'service loop' in the space behind the breaker/converter area.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 01-04-2016, 02:57 PM   #60
2016 30' Classic
I don't understand this. If I'm camping with shore power, plugged in for 5 days & have battery in the "USE" position isn't this the same thing? I wouldn't expect to fry the batteries. Is the charger in the new AS really this lame? I need to go read the manual.
caseywsj is offline   Reply With Quote
Old 01-04-2016, 05:06 PM   #61
lewster's Avatar
Lame is NOT the appropriate word…..GARBAGE is a much better description!!
Your Parallax single stage constant voltage converter is fine for producing 12VDC to satisfy the requirements of the trailer…..things like 12VDC control voltage, power for your lights, water pump, furnace, etc.
It is a HORRIBLE battery charger!!! ALL lead based batteries require a 3 stage controlled charge for optimum charging and maintenance. All lead based batteries have different charge set points but they all need a 3-stage automatic charge for complete charging.
As an example, Lifeline AGM batteries require a bulk charge of 14.2-14.4 VDC, an absorption charge of 14.2-14.4 where the charging amperage tapers as the battery fills and a float charge of 13.2-13.4VDC once it IS fully charged. And all of the above is calculated at 77ºF (25ºC).
These voltage points change inversely with temperature, but you need a temperature compensated charging system like a Magnum inverter
/charger or quality solar charge controller to affect this type of charging.
Your Parallax has a single, continual voltage output of 13.6VDC, which will neither allow for a full and complete charge or a float charge once full…..resulting in the rapid overcharging of your batteries………ANY BATTERIES!!
**All of the move is not applicable to lithium iron phosphate cells.
Old 01-04-2016, 05:18 PM   #62
2015 30' Classic
Pleasanton , California
Replacing your converter is one option. We opted for another - to add a solar battery charger that includes a three stage battery charger. We kept the original Parallax converter and simply make sure the Use/Store switch is in the Store position when we're connected to shore power. If solar isn't in your future then upgrading your converter should be.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 01-04-2016, 06:39 PM   #63
2016 30' Classic
My, my ... that's with I love about this hobby. The ability to learn new things. We came out of Class A DP and of course the converter/charger was three stage. Likely we will go the solar route at some point, but for now I suppose we will go this route:
1. Be careful when in "USE" mode when connected to shore power for extended periods of time. Need to mentally calculate how long this is safe based on discharge state.
2. When traveling, I keep in "STORE" mode ... only because I don't want the powered awning accidentally deploying . But if we need to use the fridge, then it is in "USE" mode.
3. The confusing one now is what to do when back in the storage facility. I will not have it in "USE" mode unless recharging quickly.
I guess the safest is to put a deep cycle tender (Deltran Battery Tender Plus) on it during storage. Can I just put this on while the batteries are in place, connected off and isolated with the disconnect switch in "STORE" mode?
Other than this, we love our 2016 Classic and will be taking it on a trip out west for 6 weeks in early February. Already had it in torrential rain in Dallas over t-giving weekend, so I feel pretty good about the leak test!
Old 01-05-2016, 07:16 AM   #64
2013 25' Flying Cloud
Middleton , Idaho
caseywsj: "I guess the safest is to put a deep cycle tender (Deltran Battery Tender Plus) on it during storage. Can I just put this on while the batteries are in place, connected off and isolated with the disconnect switch in "STORE" mode?"
There may be better ways, but this is how I do it. I am closely following the discussions on upgrading the converter or installing an inverter/charger. My AS is stored inside, so solar won't work to maintain it. I still have the stock group 24 Interstates (but will also be upgrading those in the future).
Trailbob is offline   Reply With Quote
Old 03-09-2016, 09:07 AM   #65
Plasma800's Avatar
houston , Texas
request please:
I'm interested in swapping my charger for a 3 stage.
What model(s) should I be looking for?
I'm familiar with the name "progressive dynamics" because that was what was in my old Class A. However, beyond that........ I'm at a loss of how to select the appropriate unit.
Also, a battery meter is a must.
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 03-10-2016, 07:14 AM   #66
switz's Avatar
2014 31' Classic
Images: 8
Here is a good outfit for the upgrade. Call and talk with Randy. One can to the upgrade themselves with their instructions.
http://www.bestconverter.com/DLS-55-...l#.VuGA28c2Ygp
HELP!! House and chassis batteries draining! weirdstuff Sprinter and B-van Forum 105 04-18-2015 05:49 AM
Rust starts quickly brijbldr Repairing/Replacing Floor &/or Frame 18 08-26-2010 05:51 PM
Rehabbing 1968 30' Sovereign Quickly .. NEED HELP! goobygirl Member Introductions 3 09-16-2009 08:48 PM
Batteries Discharging to Quickly Paul Dobbin Land Yacht/Legacy Motorhomes 23 08-20-2008 05:27 PM
Interior light bulbs burning out quickly 64Vette Lights - Interior & Exterior 21 07-17-2007 03:26 PM
