Old 03-15-2009, 08:58 PM   #1
soldiermedic's Avatar
Florissant , USA
New 7-Pin trailer umbilical wiring
I am deep in the restoration of my 53 FC, and I have just rewired all of my tail and running lamps. A new axle is on order, and I want to get my new umbilical setup before it arrives.
I have plans to replace the front aluminum panel on the trailer, and the front floor. I am curious of I should install some kind of junction box that I can wire all the lights and brakes to directly, and then attach that to the frame somewhere. I could then connect the umbilical to this when I get the floor and panel replaced.
Comments, Ideas?
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-15-2009, 09:56 PM   #2
Alumanutz's Avatar
1966 22' Safari
Chico , California
Steve, I hope this works. Here is a page from my blog on how I did it, including a wiring diagram.
NUTZ
1966 Safari ( HUGO): The Electrical Gods Hate Me
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Old 03-16-2009, 06:44 AM   #3
Florissant , USA
NUTZ,
Where did you mount this panel on your trailer?
Also...where does your cord exit the trailer at?
Steve
Old 03-16-2009, 11:26 AM   #4
Alumanutz's Avatar
1966 22' Safari
Chico , California
Steve, I did this on my 1966 Safari. On mine I had a piece of aluminum that was held on by four screws. I dropped this down and in the bellypan the wires were all twisted together and taped. I mounted the connection strip (from the big box store) to the door I removed. I also attached the circuit breaker you see in the corner. That CB is for the electric jack. Half of the cable goes to the rear for running lights and to the fuse panel, the other half is tucked into the frame and comes all the way up to the jack where it exits and has about 2 feet of slack to plug into the TV. I hope this is the answer you were looking for.
NUTZ
trailer wire, umbilical, 7 pin
Trailer Umbilical Wiring pfay Lights - Interior & Exterior 6 06-09-2013 12:48 PM
Umbilical and 7 Pin adaptor issues LowellN Lights - Interior & Exterior 48 07-18-2010 11:20 PM
Umbilical Wiring Diagrams thenewkid64 Towing, Tow Vehicles & Hitches 14 03-31-2009 12:03 AM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
1962 ambassador wiring diagram (umbilical)? Hamb7 Lights - Interior & Exterior 11 03-31-2007 10:59 PM
