Old 07-15-2017, 03:44 PM   #1
gklott's Avatar
2004 30' Classic
Johnson City , Texas
Images: 86
New 50 amp SmartPlug inlet - good location ???
We are about to cut holes into the street side skin to place the new 50 amp 240/120 VAC SmartPlug inlet. Want it adjacent to the wiring area just forward of the street side wheel well. That was beneath the rear dinette bench, but will now be in our cabinet along with the new AC power panel.
The location is just rear of the first vertical rib forward of the wheel well, and just below the horizontal rib above the wheel well. From the outside (street side, right is rear):
http://www.airforums.com/attachments...r_img_3501.jpg
From the inside (looking at street side wall, left is rear):
http://www.airforums.com/attachments...r_img_3504.jpg
As suggested in this thread: http://www.airforums.com/forums/f37/...ml#post1968962
we are filling the space between the walls with Evercoat semi-rigid, minimally expanding foam. This foam should fill in around and up to the forward rib and top rib giving extra stability.
This space is rear of the air conditioning power wire, that you can see going into the wall opening. The location seems void of wiring or other important items. It also looks to be about where the power inlet is on 2017 Classics.
Has anyone else placed a shore power inlet in this location?
Any issues in wall here?
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
gklott is offline   Reply With Quote
Old 07-15-2017, 03:52 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You *should* be able to back up that area with a piece of plywood or some other material to stiffen things up even further. I wouldn't go crazy, but it looks like it could be done cheap / easy without messing anything else up.
Old 07-15-2017, 04:09 PM   #3
gklott's Avatar
2004 30' Classic
Images: 86
Hi You *should* be able to back up that area with a piece of plywood or some other material to stiffen things up even further.Bob
Thanks. Was planning on a 6x6x1/16 in. aluminum sheet on the inside. Think snugging up to the two ribs should also help with stability.
Does anyone know how Airstream reinforces the AC power inlet on the new Classics, where it is in the same place?
73/gus
2004 30ft. Classic
Old 07-16-2017, 11:19 AM   #4
Half a Rivet Short
Hi
If they back it up, I'd bet it's with a pre-made aluminum plate. I haven't torn into mine to see.
Old 07-16-2017, 04:08 PM   #5
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Hi
In Aviation, we call that a 'doubler". FYI
MelGoddard is offline   Reply With Quote
SmartPlug hole size gklott Electrical - Systems, Generators, Batteries & Solar 6 05-10-2017 02:39 PM
city inlet & 30 amp location Mx468 Plumbing - Systems & Fixtures 9 01-19-2017 11:01 PM
SmartPlug Rawn77 Electrical - Systems, Generators, Batteries & Solar 14 02-28-2015 08:38 AM
location location location goransons Airstreams on eBay 0 12-05-2009 10:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 07:13 PM
