Old 04-28-2004, 09:34 AM   #1
New 50 amp Cable~JUNK
Its bad enough to pay $182.00 for 25 ft. of 50 amp cable, but the damn moulded male end wiring is wrong!!???
The way it is suppose to be is the top round terminal should connect to the Green - Ground. OK
The 2 side lugs should be HOT Red and Black. WRONG! One side was WHITE?? and it was HOT???
The bottom NEUTRAL should be white, but it was BLACK!! A gypsie Curse on the idiot that made that mistake and on the management that let it slide.
The only trademark on the cable is a "V", otherwise I dont know who made it. I can not return it because I cut the female plug off to wire it inside my breaker box.
The recommendation is if you buy a new cable, check it first with a battery operated test lamp before cutting it.
Dick
Navigator is offline   Reply With Quote
Old 04-28-2004, 09:36 AM   #2
summerkid's Avatar
1956 16' Bubble
Rose Lodge , Oregon
I'd try to return it even with the cut end. Your modification did nothing to change the screwy wiring at the other end, right? So the cord would have been no use to them anyway, it's so dang defective.
summerkid is offline   Reply With Quote
Old 04-28-2004, 10:05 AM   #3
LOST , Hawaii
Your ground is OK, hot and neutral are reversed. Are you looking at a plug or socket diagram, they can be confusing. Before I threw $182.50 out I would use it. When you wire it run them backwards, check the other end and make sure hot and neutral are right. It might not be code compliant, but from what you said neither was the cable and it won't hurt anything.
John
74Argosy24MH is offline   Reply With Quote
Old 04-28-2004, 11:32 AM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Boy, I sure hate to hear stuff like that, but this is what you can expect from many offshore factories, I see it every day in the trade.
I for one believe in "if you want it done right do it yourself".
25' of 6-4 SO cord $39.00, (25 x $1.56). 1 ea. 250VAC 50amp connector $14.00. total job $53.00. for the pig tail. If you want the extension cord add $22.00 for the female end, total job $75.00 + the governor's cut for 25' extension cord.
Peace
Gary
Janets Husband is offline   Reply With Quote
30 amp or 15 amp / 59 Traveler bkpine Electrical - Systems, Generators, Batteries & Solar 14 09-14-2006 07:10 PM
30 amp vs. 15 amp plug? 63flyingcloud Electrical - Systems, Generators, Batteries & Solar 7 09-29-2005 12:26 PM
powerlines, 30amp vrs 50 amp skip Electrical - Systems, Generators, Batteries & Solar 21 01-22-2004 11:31 PM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 05:12 PM
30 amp outlet john hd Electrical - Systems, Generators, Batteries & Solar 20 02-26-2003 01:54 PM
