Old 09-08-2010, 05:22 AM   #29
x
XXXX , XXXX
Most government (city, county etc) require permits for any wiring additions. Makes perfect sense given the homemade connections discussed here, not to mention stupid mistakes made by so called professionals.
wasagachris is offline   Reply With Quote
Old 09-08-2010, 06:11 AM   #30
Hagerstown , Maryland
Originally Posted by billberk View Post
I accidentally got plugged into 220 at the lake earlier this year and now I have a new AC, refrigerator, convertor etc...
billberk, I'm gathering data on mis-wired RV outlets for an industry report. Was this "220 at the lake" your own property, or was it a campground? Any other details would help. For instance, was this an improperly wired NEMA-5 (20 amp) or 30 amp outlet, or were you using an adapter of some kind on a 50-amp 240 volt outlet?
Thanks for any details... Mike Sokol
jmsokol is offline   Reply With Quote
Old 09-08-2010, 06:44 AM   #31
Permits AND inspections are required in many localities. But don't expect inspectors to be any more knowledgeable about 30-amp, 120-volt plugs than your average electrician. I've followed up on a lot of "inspected" panels which don't meet NEC grounding requirements that have been in place for 10 years. And a number of southern state Inspectors have refused to follow the latest National Electric Code guidelines about AFCI (Arc Fault Circuit Interrupt) usage in new homes. They state that the $300 additional cost to a new home would be a hardship on the electrical contractors. Give me a break... adding $300 onto the price of a new $150,000 home isn't going to be a hardship for anyone. But AFCIs will detect any sparking wires and trip before they cause a fire. A GFCI (Ground Fault Circuit Interrupt) will only trip if it detects any current going to ground. I'm not sure what the upcoming 2011 NEC says about RV wiring practices, but I'll soon find out and write it up on The No~Shock~Zone.
Mike Sokol
Old 09-08-2010, 07:21 AM   #32
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by Harleyjohn View Post
What should I expect to find when I plug the converter into a 110 line?
John
With the batteries connected to the converter you should see about 13.5 volts or more out of the converter.
For this test I would use a known 20 amp circuit and an extension cord. If the 20 amp breaker pots when you plug in the converter is toast.
2004 Excursion 4x4
Old 09-08-2010, 10:18 AM   #33
Wise Elder
Jammer's Avatar
2010 30' Classic
Another electrical thread with more ADVICE than FACTS. When I was new to the forums I tried to help diagnose electrical problems over the 'web until somebody almost burned themselves because they couldn't explain the problem clearly and didn't know the basic risks and safety measures involved in working with electricity.
This is an area where QUALIFIED people observing the facts IN PERSON should be a prerequisite to offering any advice or suggested steps... which then should be implemented by or under the supervision of QUALIFIED people.
Even simple advice to measure the voltage at an outlet with a multimeter can lead to injury if the person MAKING the measurement does not know that it is dangerous to proceed if ... it is raining ... the test leads are wet ... the test leads are plugged into the CURRENT jacks on the meter ... or are damaged. Or, if the person MAKING the measurement has a pacemaker, or is barefoot.
These aren't flashlight batteries we're talking about here.
Originally Posted by Clyde43 View Post
Had electrician wire 30 amp at my home. Got Bambi home plugged in and breaker threw with smoke and flames. Have I fried my whole trailer? Lights still work on batteries. Don't know is reversed polarity or something else. I think electrician ran 220 to 30 amp plug is it suppose to be 120 run to it? Help please!
Here's the details...
Plugged into 30 amp one 20 amp breaker threw and hot smell. Then we tried (like idiots) 110/20 household plug. Fire and smoke shot out of breaker box (no breakers thrown) and we unplugged. We took off breaker box cover but saw not damage visually.
Sounds bad to me. What do yall think? Do you think breakers stopped damage or everything is gone? Now I have to find a Rv service place I trust. Any reccommendations in Alabama? Wish we were close to Ohio.
Who KNOWS? I can GUESS along with everyone else. Which breaker? Is there any thermal damage to the insulation on the wiring in the breaker panel on the trailer? Is there heat damage to the shore power cord? Is there visible damage to the breaker that tripped? Can the OP tell? Can the OP remove the breaker from the box, safely, and evaluate its condition and operation? Can the OP even remove the breaker panel cover and evaluate this situation safely without creating further risks of damage and injury?
Clyde43 I would hold the electrician financially responsible for the damages if any to your trailer.
Exactly. No electrician should wire a TT-30R receptacle to a 240 volt circuit. Ever. If they did, they made a mistake, and they should be liable for repairs. Call your insurance agent. Call your attorney. Call the electrician who screwed it up.
Originally Posted by TG Twinkie View Post
If you run the AC on 14 gage wire, you will destroy the AC compressor motor.
That's just wrong. I'm still selling tickets to the upcoming meltfest where we're going to run an A/C on 14 gauge wire for a week at 100 volts in front of witnesses just to provide a counterexample.
I should have looked at my meter but I didn't. It cost right at $5000.
Hope your damage is not as extensive.
I would be surprised to learn that such wholesale replacement was really necessary. With the fridge, for example, a fuse replacement should have been sufficient, or a replacement of the heating element if there is no fuse.
Originally Posted by 87MH View Post
Before Clyde43 proceeds I think the SRO (Service Requisition Order) needs to be examined...if the original SRO says something like "Install an RV 30 breaker..." then maybe there is a valid claim. On the other hand, if the SRO only says something like "Install a 30 amp breaker...", then without further guidance from purchaser/homeowner, the installer could easily (mis)understand that his job is to install a 30 amp dryer type of receptical (much more common).
If the whole thing was done verbally - well it's the installers word on what he UNDERSTOOD against Clyde43's word on what he WANTED.
Avoid verbal communication - especially where money and liability is concerned - get it in writing.
No electrician in any jurisdiction in the U.S. is allowed to wire an outlet for the wrong voltage even if that's what the customer says they want. Do you think you could get an electrician to wire a regular household 15A outlet for 240 volts? Even if you asked? Well, a TT-30 outlet is, specifically, a 120 volt outlet, just like the regular household 15A outlet.
I have a '92LY and wanted to be completely prepared for all camp site electric posibilities, so I bought a 50A to 30A adapter to use at campsites where only a 50A outlet is available.
I was told that the 50A is like the other service at campgrounds and are 110/115v.
When I asked a sales person at an RV store if the camp site 50a service can be 220v.
He said that it could and that the 50/30A adapter directs each 110 leg to where it does no harm.
ANY TRUTH TO THIS INFO???
Yes, the typical 50A campground outlet is dual voltage, and the adapters are wired in a way that provides 110 volts.
Originally Posted by HowieE View Post
With 220 feeding the panel you most likely damaged any 120 system that was on when you plugged in. That may be limited to the converter if all else was turned off. If the micro wave was on the controls in it way be fried.
The refig. controls are 12 volt but if it was on the electric heating element may be open now.
You can use the 120 adapter idea to test things as long as you do not attempt to run the AC. That is the only thing that will draw more that the current limit of a 20 amp line.
I think this sort of troubleshooting advice is potentially dangerous when given to someone who has no background in electricity. For example, the heating element in the fridge could be burned out and shorted to ground.
I would disconnect the converter and test it separately on a 20 amp line as I think it is toast.
How do you KNOW? SOME converters are inherently dual voltage and can run ALL DAY on 240v. IF it is damaged do you think it is SAFE to perform such a test?
So, I would encourage everyone to STEADY ON with the well-meaning advice and consider the CAPABILITIES of the OP and the SAFETY questions such troubleshooting steps beg.
My advice for the OP is to seek out QUALIFIED professionals...
...both for the electrical troubleshooting
AND answers to the questions of who pays to clean up the mess.
Old 09-08-2010, 04:01 PM   #34
x
XXXX , XXXX
Congrats Jammer someone had to say all you said. The same goes for propane. If you are not fully qualified get someone who is. Electricity and gas are dangerous things if not handled properly. Is saving a few dollars worth your life.
Old 09-08-2010, 04:19 PM   #35
Over59's Avatar
Putnam , Connecticut
Images: 37
Ditto...
Over59 is offline   Reply With Quote
Old 09-08-2010, 05:21 PM   #36
Originally Posted by Over59 View Post
Ditto...
Double Ditto....
Old 11-03-2015, 08:41 AM   #37
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
even the professionals....
I just had a new house built with a 30 amp outdoor receptacle next to the Airstream driveway. Just before finishing the house, I plugged the cord in and BAM! The Surgegard blew up. Turns out the electrician wired it wrong.
He said "well, there were no markings on the receptacle." He replaced
the Surgegard and fixed the wiring. Lucky for him, the Surgegard was only $300. The cost to rewire the trailer would have been more.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 11-03-2015, 08:52 AM   #38
Actually, every TT-30 receptacle (the standard 30-amp/120-volt outlet you're referring to) is clearly marked "125-volt maximum". But it is rather small lettering and it's typically black-on-black. I've been trying to get the electrical industry to make the labels bigger, but it's an uphill battle. At least your electrician did the right thing and replaced what he blew up due to his miswiring. But I have emails from RV owners in similar situations that had the electrician asking the owner to cover the repair on their own homeowner's policy. And some of these repairs can be in the tens of thousands of dollars.
Mike Sokol - The No~Shock~Zone
Old 11-03-2015, 09:05 AM   #39
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Sounds like he did like most electricians do.... Wired it 220v!
Old 11-03-2015, 09:51 AM   #40
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Had the same problem on our new house. Plans called for 30 amp "RV" outlet in the garage. First time I plugged in the Bambi II it fried the Univolt and tripped the breaker. Was wired as 220 volt. I was replacing the univolt anyway so all the electrician had to do was rewire the outlet.
BambiTex is offline   Reply With Quote
Old 11-03-2015, 12:06 PM   #41
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
bump so I can watch this thread. BTW jmsokol, nice website. good info.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 11-03-2015, 07:34 PM   #42
2007 22' International CCD
Now I'm super glad I wired my own plug--following the very clear directions right on the box.
It's been my experience the so-called professionals just assume, and do what they have always done. Had similar issues with a plumber that claimed 39 years experience when he plumbed our house and ignored my request to put the outdoor faucets on a separate circuit with a drain valve for winter. First freezing weather blew out all the hose bib lines. I fixed it the way I told him to do it, no more issues. Air won't freeze😄
I get suspicious when someone tells me 'that's the way we always do it around here...' and I know better!
KE4GNK/AE
2nd Trip...Flames & All strohmdl Classic Motorhomes 9 07-30-2009 05:33 PM
30 amp plug schematic gparker Electrical - Systems, Generators, Batteries & Solar 8 07-13-2008 09:41 PM
30 amp Plug Differences Cracker Electrical - Systems, Generators, Batteries & Solar 7 09-18-2006 07:45 PM
30 amp vs. 15 amp plug? 63flyingcloud Electrical - Systems, Generators, Batteries & Solar 7 09-29-2005 12:26 PM
got flames? john hd Airstream Motorhome Forums 3 02-09-2003 07:54 PM
