Originally Posted by Vantair
Yup ! And reason got on the phone with B.B. ready to order two when the hmmmmm hit me...
Almost 4 x the cost for spec’d usable 214ah (@50% DOD). Hopefully never below 30%.
Just found another similar sized AGM solution from “Centennial” 200ah 279.00 ea (also a sweet 8.9in height) few pounds heavier than US Batteries so perhaps more lead and lifespan ?
Anyone have experience Centennial AGMs ?
Hi
With the lead acid's you can only get about half of the amp hours as useful power. A 220 AH lead acid gives you 110AH from full charge to 50% (where you stop to avoid damage).
The lithiums work differently and are rated differently. The 100AH rating refers to the usable amp hours on the battery. Generally it's a 100% to 10% sort of number. Lithiums are quite happy to operate over that kind of range. There is no need to limit them at something like 50%.
Bottom line is that a 100AH
12V lithium gives you the same usable power in the RV as a 200AH lead acid stack. Yes, that's a bit weird. It also is a function of lead acid specs dating back to the 1800's and lithium specs being much more modern.
Next up is life of the batteries. Most lead acid manufacturers talk about something like 800 charge / discharge cycles on the battery at low discharge rates. The number is highly dependent on the depth of discharge, so you can find all sorts of numbers to quote. Lithiums get cycle number ratings in the 3,000 to 5,000 range. Those are for 100A or 20A discharge rates on a 100AH battery. Bottom line is that cycle life is rated to be *much* higher (like 6X) for the lithiums.
Many people have observed that regardless of charge cycles, lead acid's have a limited lifetime. Even with modest charge cycling, getting 5+ years out of a set is not what most people see. Many change out batteries in 3 or 4 years. It is alleged that lithiums have a 20+ lifetime on the same sort of basis. We haven't been running lithiums for 20 years so, only time will tell.
So right out of the starting gate, you need 2X the amp hours of lead acid. Next up is the likelihood that lithiums last a whole lot longer. As an example, one 100AH lithium (at $1,000 delivered) on day one is the same as two $500 100AH lead acids. If the lithium lasts 4X as long, that goes to $125 for the tradeoff price on the lead acids. At 6X the magic tradeoff number would be $83.
Are lithiums the perfect answer to all battery needs? Of course they aren't. They do have their issues. They are a new technology and there most certainly is risk involved. The upfront cost is high and the analysis above does not factor in any "cost of money". On the flip side, running out of battery every few years has a cost as well.
Lots of factors .....
