Old 02-11-2019, 07:14 PM   #1
1976 24' Argosy 24
Milford , New Jersey
Need to replace receptacles in a 76 Argosy
Hello all. the outlets in our 76 Argosy need to be replaced. The plug sockets are loose and don't hold a plug well anymore. Upon disassembly i was surprised to be faced with these outlets that I now understand to be used in mobile homes and apparently old airstreams. Do I try to source this style of receptacle or do you all replace them with something more conventional? There are no electrical boxes in the wall. These are called self contained receptacles.
Thanks for your time. G
Name:	Argosy outlet 1.jpg
ID:	333445   Click image for larger version
Name:	Argosy outlet 2.jpg
Gkiesel is offline   Reply With Quote
Old 02-13-2019, 12:55 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
They were also used in my 2010 and are still available. Here is one source: http://www.dyersonline.com/diamond-s...eceptacle.html
You may find that there is insufficient depth for a conventional outlet box.
Old 02-13-2019, 03:18 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Vintage trailer supply sells the shallow outlet boxes that will fit in the trailer walls, if you decide to go with a conventional off-the-shelf receptacle.
TheGreatleys is offline   Reply With Quote
Run power off two 20amp receptacles? KYAirstream Electrical - Systems, Generators, Batteries & Solar 10 10-29-2012 11:19 PM
Different DC Cigarette Plug Receptacles? rseagle Electrical - Systems, Generators, Batteries & Solar 5 08-14-2010 08:03 AM
have 110 receptacles no overhead lights michaelsessa Lights - Interior & Exterior 4 04-29-2007 07:45 PM
Interior receptacles behind curtains davidz71 General Interior Topics 1 01-31-2006 08:53 PM
Electrical Receptacles don't work now goldenlily Electrical - Systems, Generators, Batteries & Solar 1 10-03-2005 01:39 PM
