06-22-2019, 08:05 AM
2018 25' International
Lewisville
Need Short (10') Locking 30 amp Power Cord
I've searched high & low to no avail. Anyone know where I can get one of these? The 90 degree connection type would be my first choice!
I've found plenty of extension cords, but they don't have the locking attachment.
Matt & Roxanne
2018 FB Twin INTL Serenity (The Flying Squirrel)
2019 F250 DIESEL (Ferdinand)
@tflyingsquirrel
06-22-2019, 08:27 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I do not know what the locking attachment is. I use a 10 foot extension I bought from Amazon. If someone makes what you are looking for Amazon probably lists it.
06-22-2019, 08:29 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
The only way that I know of to get a 10' power cord for your Airstream is to build it yourself.
I have done exactly that. I had found over the years that very often, I didn't need a full 30' shore power cord. The 30' cord was sometimes hard to handle, especially in colder weather. I had a backup 30' foot cord which I cut into 10' and 20' lengths. I purchased one trailer end and one power post end on Amazon and wired the ends.
I now have a 10', 20', and 30' cord. I rarely use the 30' cord.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
06-22-2019, 08:42 AM
Sag Harbor
, New York
^^^^^ x2
Simple to do.
06-22-2019, 08:48 AM
2018 27' Tommy Bahama
Marana
Here is one option. It’s longer than you want but it’s all I could find. I have the 50amp version of this and it is MUCH simpler than wrestling the “anaconda” cord.
https://amzn.to/2Y1LGtO
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
06-22-2019, 09:32 AM
2015 27' FB International
Miami
Can anyone share the gauge of the cord so I can make my own? I have made a power cord for my generator to the house using parts from home depot so I can probably do the same if I knew the cord gauge. Assuming I can find the correct ends.
06-22-2019, 09:46 AM
CruiserGa
2004 25' Safari
Gainesville
, Georgia
The link in the post above shows a 10 ga cord...
2007 22' International CCD
Corona
10 gauge stranded copper wire minimum
Ends available on Amazon. Look for RV-30 connectors for the plug end. Other end depends on how your trailer is wired.
06-22-2019, 09:58 AM
Sag Harbor
, New York
The wire gauge of your OEM cord should be written on the cord. Match that AWG . . . for 30' [not 50'] probably #10, as others have posted.
Your owner's manual probably has the same spec in the back.
Peter
06-22-2019, 10:32 AM
2017 25' International
Calgary
, Alberta
If your concern is related to keeping your power cable nice and tidy, may I suggest you consider something like the Cordpro cord organizer available on Amazon. I saw somebody using one last week and, based on his feedback, plan to order one for my 30’ cord.
06-22-2019, 11:18 AM
Miami
Thanks great suggestions
06-22-2019, 01:33 PM
2017 27' International
Antes Fort
, Pennsylvania
Since the subject is power cords, is there an adapter that has a lock? I bought a 30 Amp PC from Walmart as a spare. When I needed it I realized it wouldn't work because it doesn't have that locky thingy on the connector. After a trip to the local RV store I bought a correct power cord. Am I stuck with the Walmart cord which they advertise as an RV power cord? Seems like there must be an adapter out there some where. Thank you.
06-22-2019, 02:12 PM
Tampa
06-22-2019, 02:42 PM
2013 25' Flying Cloud
Wheaton
Consider a two part solution; a 12’ 30A marine cable (male & female twist lock ends) and a 1’ 30A trailer plug to twist lock adapter. You will also want to get a collar and two rings to create a tight waterproof locking connection between the adapter and cord. Marinco makes these. An added bonus is that you can use the 12’ cord as an extension to your existing shore power cable.
I actually use this setup as my primary shore power cable where I have a 12’, 25’ & 50’ cable to choose from to mate with the adapter. At a Canadian campground, even the 50’ cable wasn’t long enough so I connected two cables together to make it reach. I was careful to limit my current through this cable.
Of course, with all of the promotion to the new SmartPlug, having two twist lock connectors would certainly be a death sentence, so ignore what I wrote above.
Greg
06-23-2019, 09:49 AM
BALLWIN
, Missouri
Trailer electric cord lock
Try to keep it simple. Purchase a pad lock with a long shank that is wide enough to go around your wire. slide the shackle of the lock over the cord and attach it to the breaker box locking hole, every box has one. The lock will keep the ends from being pulled through the shackle and you could use the lock other places also.
06-23-2019, 04:45 PM
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
06-30-2019, 09:39 AM
Tampa
Originally Posted by cazual6
I know exactly what you are trying to do.
I assumed the OP had a place to park the trailer at his property and only needed 10'.
Finding a 10' 30 amp power cord with molded plugs AND a right angle female is a tall order.
06-30-2019, 11:03 AM
Lewisville
Exactly! I'm not sure if I'd rather have the 10' cord without the 90 degree connection, or just go with a good 30 footer that has a 90.
Thanks for all the responses,
Matt & Roxanne
@tflyingsquirrel
06-30-2019, 11:43 AM
Fort Myers
This what i bought, and then purchased 15' 50 amp ext cord
Camco Heavy Duty Locking Female PowerGrip Adapter with Innovative 90 Degree Bend Design - 50 AMP Standard Male / 50 AMP 18" (55562)
