Old 12-27-2014, 07:58 AM   #15
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Christina!
Something occurred to me as I read your most recent post. Is it possible that your electrician may have wired your RV outlet as 220 Volt rather than 110 Volts? I know that this has happened to others, and it has almost happened to me twice in the past -- this is an installation uncommon to most electricians and the outlet does bear some resemblance to the more common range/dryer outlets.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 12-27-2014, 11:19 AM   #16
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
one tenth of an amp VAC WILL KILL YOU. I don't like the looks of the new work plastic boxes and blue masking tape. ANY wiring splice should be in a MOUNTED GANG BOX and in armored/flexible conduit.
VERY IMPORTANT: AFTER AN ELECTRICAL SHOCK, IF YOU FEEL ANY MUSCLE SORENESS BETWEEN WHERE YOU WERE INJURED AT ENTRY AND EXIT, AND HAVE A DECREASED URINE OUTPUT, SEEK MEDICAL ATTENTION RIGHT AWAY. THE MUSCLE TISSUE BREAKS DOWN AND ITS COMPONENTS WILL PLUG UP YOUR KIDNEYS.
I'm glad you walked away from this one. Please seek care if you don't feel right. Don't minimize your symptoms. All the best.
NavyCorpsman is offline   Reply With Quote
Old 12-27-2014, 12:28 PM   #17
1966 30' Sovereign
Goleta , California
OK, I concluded that my shock came from touching the bare metal in the test outlet. Clumsiness on my part. The good news is that the trailer is not shorting. The noise I heard was the rat repellent plugged in. I now know that the black line is the 110 V. The other line with a red, a blue and a white wires is the 12V output. Am I correct in assuming that red is POS, Blue is NEG and white is ground?
Cris
Cristina1966 is offline   Reply With Quote
Old 12-27-2014, 01:06 PM   #18
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
DC neg (-) and ground is the same thing in an Airstream.
At the battery connection DC neg (-) is usually black. Red should be (+) at the battery connection.
BUT, there is no guarantee. The color of wire and wire location can be changed. So you must know how to determine which is which.
Neg (-) will be the wire that has one end is connected/bonded to the trailer frame, regardless of color.
Pos (+) will be the wire that has connected to the (+) battery terminal or the (+) converter terminal, regardless of color.
Alan
Old 12-27-2014, 02:02 PM   #19
1966 30' Sovereign
Goleta , California
Hi everyone,
I reconnected the converter using all the information you provided and the electrical works beautifully. Wayward was right, I must have touched a raw wire while plugging the appliance. The good news is that the trailer is not shorted. Thank you all for the good advice,
Cris
Old 12-27-2014, 04:13 PM   #20
Wayward's Avatar
Cary , North Carolina
Originally Posted by Cristina1966 View Post
Hi everyone,
Cris
You are welcome - and remember - one hand behind your back
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Reconnecting black water tank Lfemat Waste Systems, Tanks & Totes 1 05-22-2012 01:36 PM
reconnecting Univolt jubei Batteries, Univolts, Converters & Inverters 6 04-18-2012 05:13 AM
Need electrical help '61 Safari Rick Dotson Electrical - Systems, Generators, Batteries & Solar 4 04-23-2004 07:01 PM
Need help!-Finding thread about electrical cord. WayWard Wind Our Community 5 03-25-2003 07:37 PM
