Old 07-04-2011, 05:55 PM   #1
1969 27' Overlander
Vestavia , Alabama
Need help w/ my '70 I just purchased - Running and tail lights
This is my first RV purchase and I need help with the tail/brake lights and other running lights. I had a faulty battery and have replaced that as well as checked my towing vehicle to ensure the power from my vehicle is working, and none of the lights still work.
Any help is appreciated in advance. It would be nice to find a "fix all" fix/fuse/switch that would help vs. me having to splice off of the out from my tow vehicle. All the lights do not work. I also have no idea if any of the other towing accessories work like brakes, battery charger, etc...
Aubiexx is offline   Reply With Quote
Old 07-04-2011, 06:34 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The first thing I would do is to make sure you have a good ground/common connection.
Then I would use a battery charger to test and trouble shoot all of the lighting on the trailer.
I will assume you have a 7 pin plug.
Start by connecting the black lead of your battery charger to a clean spot on the tongue of the trailer, scrape that spot to where it is shiny metal.
Then take the red lead and touch each of the pins one at a time and look to see if any lights come on.. The center may not be connected to anything and one of the 6 around the outer circle of pins is the ground/common wire.
On the trailer plug one pin will be for the tail and clearance or marker lights. There will be a pin for each of the turn signals (left and right); these will also be the brake lights. The fourth pin will be for trailer brakes; The fifth pin will be the charge line to the battery in the trailer. The sixth pin will be common/ground.
If you have a helper to watch the lights it makes it easier.
The chances are good that your trailer is not wired to match your TV. A different standard was used back then. So you will need to determine what is what on the trailer and then change it to match your TV.
If you have a VOM meter and know how to use it. The job will be easier.
We are here to help so tell us what you do or don't find and then we can guide you thru to a successful job.
Old 07-05-2011, 05:46 AM   #3
1969 27' Overlander
Vestavia , Alabama
That worked perfectly. Thank you. Now I guess I need to see why they aren't working when hooked to my Tow Vehicle. Looking forward to this forum.
Old 07-05-2011, 07:18 AM   #4
Most iportant project is to make the coach weatherproof.
Unless they have been replaced, all the exterior gaskets should be cracked, which allows water to leak into the trailer.
Old 07-05-2011, 05:34 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe that your trailer is wired like my '74 Argosy. Here is how I wired the 7 pin plug on my trailer. I have a '98 Dodge truck which is wired to todays standard.
Name:	7 PinTrailer Plug Wiring.jpg
Old 08-07-2011, 07:22 PM   #6
1974 21' Globetrotter
staten island , New York
Hi all, I'm having a similar issue with my 74 land yacht. Where might i chek to see that i do have a good ground. Last time i checked the outside lights they worked but we have been renovating so maybe something got cut, chopped, removed, who knows
thanks in advance
dcorona is offline   Reply With Quote
Old 08-07-2011, 08:52 PM   #7
Splitrock's Avatar
Sioux Falls , South Dakota
Mine is grounded at the 7-way trailer terminal location. I used a 7-way tester to test the tow vehicle, the cord, and the trailer. I tested all three components separately. I used a small battery charger, a jumper light, and a small multi meter. When I had everything all working separately I plugged the cord into the tow vehicle. I had two wires reversed in the cord. I reversed those two wires and everything worked to a standard 7-way plug.
I have three other trailers that use the same two tow vehicles and all are interchangeable. Plug and go.
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 11:26 AM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 05:45 PM
Running / Tail / Brake lights 77 Argosy Landmammal Lights - Interior & Exterior 4 04-08-2011 12:24 PM
white,black, green wires in taillight bundled togather robertel Lights - Interior & Exterior 20 03-10-2011 10:30 PM
Towing new to me 1984 34' worried about lights David Meyer Lights - Interior & Exterior 2 10-03-2010 08:53 PM
