Old 01-13-2004, 11:44 AM   #15
Stinky's Avatar
inteli-power
This is the one I saw http://www.campingworld.com/browse/s...m?skunum=17299
Stinky is offline   Reply With Quote
Old 01-13-2004, 11:55 AM   #16
For another $20.00 you can get an Airstream univolt that puts out 55 amps.
A 40 amp converter would be considered light duty for 1969 and up coaches.
Old 01-13-2004, 12:01 PM   #17
Stinky's Avatar
Univolt
Even if I only have a 30 amp AC service I can use a 55 amp univolt? I am totally new on this DC stuff.
Old 01-13-2004, 12:17 PM   #18
Stinky.
30 amp city power service is 3600 watts.
40 amps at 12 volt DC is 480 watts, and 55 amps is 660 watts.
Don't confuse city power with 12 volts. They are two very different animals.
Old 01-13-2004, 04:34 PM   #19
wannabefulltime'n's Avatar
Weirton , West Virginia
Andy,
What is the pros and cons of NOT using a converter, just using an automatic smart charger (automotive type) to maintain your deep cycle batteries?
wannabefulltime'n is offline   Reply With Quote
Old 01-13-2004, 05:40 PM   #20
The so called smart chargers, do not have an internal brain.
Therefore they don't know when to trickle charge or full charge.
A univolt has the brain, and keeps the battery or batteries topped off. When a load is applied, the univolt provides the current for that load, without depleting the battery charge.
If you have a 40 amp charger, the excess current must come from the battery.
Airstream concluded that a 55 amp charger was the most ideal to use. It is for that reason that Airstream has used the same univolt for several years.
Old 01-13-2004, 05:53 PM   #21
Stinky's Avatar
univolt
Thank you Andy, for the info you will be hering from me in the next few weeks for this and a few other items.
Old 01-13-2004, 07:14 PM   #22
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
wannabe,
Not to take away from Andy's business, Inteli-powers are made in 30, 40, 55 and 80 amp models. The univolt is a good unit and so is the Inteli-power.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-14-2004, 04:27 AM   #23
New Borockton , Alabama
Images: 21
Inteli-Power
Actually, PD has stopped making the 55 amp but there are a few left out there on dealer shelves. The 60 AMP replaced it and the price did not increase. We sell the 60 amp for $184.95 including the Charge Wizard. We usually have the 55 amp Parallax (7455) in stock also but it just doesn't sell like the Inteli-Power with Charge Wizard, except to a few Airstream people that insist on it because Airstream used it and calls it the Univolt. Most prefer the reliability of the Inteli-Power along with the control of the Charge Wizard. The Charge Wizard does have an "internal brain" and varies the output based on the battery state. Camping World charges $233 for either unit.
Randy
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 01-14-2004, 07:20 PM   #24
Thanks Everyone,
I just ordered the Inteli-power 60Amp with the Charge Wizard from Randy. It sure is great to have "fellow streamers who have been there ... done that" to get good information from.
Old 01-14-2004, 08:18 PM   #25
Univolt Biography needed
Our Univolt 5 is we guess the factory installed one. It is in a darn awful place to investigate.
Do any of you know if there is info available to determine the different models?
Were all 74 univolts #5 or did the model # depend on the size of the trailer?
Was there a Univolt 6 ,7, 8, etc. how bout 1, 2, 3, as well?
Is the company or its decendent still in business?
Litton Industries had something to do with it in 74 apparently as I see their logo on the Univolt cover.
Is Litton still around?
Has anyone tried to contact them for old literature and data?
We are a long way off on Univolt but I feel it will need repair too.
TIA
$&V
Sue&Von is offline   Reply With Quote
Old 01-20-2004, 06:37 PM   #26
Randy,
Just received my Intelli-power and Charge Wizard! Compared to the Univolt in apprearance, they sure have came a long way in 30 years. I will not install it until I have completed the re-insulating and re-placed the interior panels. Hopefully within the next month. Thanks for your input again, good price, timely delivery, and the lady that took my order was very friendly. That is what I like when dealing with ANY business.
Sue&Von
I looked in my Service Manual and my Owners Manual, no mention of a Univolt "5" "6 - 7 - 8 - etc." Maybe you can get an answer from A/S or from Andy @ Inland RV. He gives great information and has plenty of experience to back it up.
Ray
Old 01-21-2004, 08:37 AM   #27
Univolt numbers stopped at 5.
Litton has nothing to do with Univolts at this time.
Will your power on light work correctly with the Intelli-power?
Old 01-21-2004, 10:48 AM   #28
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Power sizing
In my other life (Not the wife's Trailer repair guy) I maintain and install DC power systems for Communications sites. These systems work 24/7, 365 days a years for 20 years straight.
The theory is the same for a trailer.
I hope this will shed a little light on this subject.
Design questions for a system are:
1.) What is the load on the battery going to be?
2.) What is the expected growth?
3.) How long does the system need to run on the battery?
4.) How much space is available for the battery set?
In a trailer this would also include a.)weight, b.) weight distrbution.
Once you know these factors you are ready to make a determination on what size your battery plant and (Charger/Converter) should be.
Storage Batteries are usually rated at a 8 hour discharge rate
[the maximum current flow that can be supplied for 8 hours], look for this rating to tell you how much power the battery will supply. The (Cold Cranking Amps) does not really mean much in this useage of a battery.
Example: Your rig will draw 300 Watts when at full load. 12/300=25 amps (E/P=I Wattage devided by Voltage equals Current) you want to be able to run for 16 hours on battery. The battery should be rated at 55 Amp Hours at a 8 hour rate. You should always derate your battery by 10% for lost capacity, this will always happen.
That should help you get the correct size of your battery needed for your rig.
Now for the Charger/Converter.
I like to look at this question from 2 directions.
1.) How long do I want to take to recharge my battery plant after a deep discharge?
2.) How good is the equipment at correctly "Floating" my battery?
Question 1: How long do I want the recharge to take?
For example, take the total capacity of the battery say 125Ahr8, this would take about 12.5 hours to rechage at a 10Amp charge rate. a 50 amp charger would take about 1 1/4 hours to charge the battery.
Also you must subtract any other load you have running from the current available for the battery charge. I also derate the system by 3% for losses and age.
Question 2: How good is the Charger/Converter at Floating the battery? A car battery charger is not a device I would use to maintain a trailer battery, most of them are constant current and you want a constant voltage device for Floating a battery. The charger must be able to provide a constant voltage while providing variable current to the battery while charging.
This type of device is made to keep a battery at a fixed charge(full) without boiling away its battery electrolite.
One other issue that is often overlooked. Wire.
I don't care what anyone says use the largest gauge wire that is practicle. We use 4/0 and 2/0awg when ever possible even though it will never carry that amount of load. We look at the voltage drop of the wire loop( total length of the wire to and from the battery plant. The larger the wire the less loss (heat/voltage drop).
I know this is rather long but it will work for you if you work the hype.
That's my $0.02
Peace
Gary
Janets Husband is offline   Reply With Quote
