Old 08-20-2017, 04:36 PM   #1
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Need Help Finding Battery Water Filler
Been looking for a Battery Water Filler, looks like a turkey baster. Been to auto parts stores, Walmart, Camping World, etc. etc. All I can find is the "Automatic Water Filler" that Camping World sells and I have used with marginal success. Has anyone out there have any idea where I can get one?
zapper is offline   Reply With Quote
Old 08-20-2017, 05:03 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Just a thought .... use a (glass) turkey baster ....
Old 08-20-2017, 05:12 PM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I also could not find one at any local stores and ended up buying this one on Amazon.
Old 08-20-2017, 05:47 PM   #4
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
I use one of these, saved from when I had a MH with 8 batteries:
https://www.amazon.com/s/ref=nb_sb_s...matic+shut+off
The Ice Man is offline   Reply With Quote
Old 08-20-2017, 05:47 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use a measuring cup and dedicated funnel. Keeping it simple works for me.
MICHAEL
Old 08-20-2017, 07:28 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I have never used anything but a funnel.
CRH is offline   Reply With Quote
Old 08-20-2017, 07:37 PM   #7
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I use a basic plastic turkey-baster type thing with a rubber bulb. Works fine. There's no mystery here.
Rocinante is our 2014 International Signature 27FB
Old 08-20-2017, 07:49 PM   #8
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
I have used a plastic house plant watering can with a long curving spout.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 08-20-2017, 09:12 PM   #9
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
https://www.amazon.com/OXO-BPA-free-...+turkey+Baxter
This is what I use.
Old 08-20-2017, 09:23 PM   #10
FishByFly's Avatar
2019 22' Sport
Fort Worth , Arkansas
Found mine at Pep Boys.
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is online now   Reply With Quote
Old 08-20-2017, 10:52 PM   #11
Korry Classic
2007 27' Classic FB
La Pine , Oregon
Try dollar stores
KorryClassic is offline   Reply With Quote
Old 08-20-2017, 11:06 PM   #12
1979 23' Safari
Wayland , New York
I use a small irrigation syringe(syringe sans needle) I got at a tractor/ranch supply store. I usually have to add very little water that a full syringe is enough for the whole battery.
Old 08-20-2017, 11:09 PM   #13
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Pep Boys. NAPA. O'Reilly's. Harbor Freight. Autozone. Amazon.
https://www.amazon.com/Cycle-Battery.../dp/B00NB808P0
Cats and ultraleather Airstream upholstery don't mix!
Old 08-21-2017, 12:34 AM   #14
Mollysdad's Avatar
Yep. Also sold at O'Reilly Auto Parts stores.
The only down side is it's hard to use with a gallon of distilled water. But it can be done.
Old 08-21-2017, 01:39 PM   #15
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I just use the battery acid tester itself.
One fill is good for about 1-1/2 cells.
Distilled water from the local Sobeys, $0.99 for four litres.
MelGoddard is offline   Reply With Quote
Old 08-21-2017, 03:12 PM   #16
CruizinDux's Avatar
Tracktown USA , Oregon
I use a picnic type mustard/catsup squinter container....$ 1.00 at the dollar store. I keep it in the aft storage compartment held in place by a 2" pipe strap.
bob
CruizinDux is offline   Reply With Quote
Old 08-21-2017, 03:28 PM   #17
2015 25' FB Flying Cloud
Sandy , Utah
The one that Protagonist showed is the best way to go. I have used one for 30 years for cars, boats, and trailers. The tip is spring loaded and will only allow water to flow when it is pushed into the cell on the battery. When the gurgling noise stops the cell is full to the proper level. It holds about a quart of distilled water and is easily refilled. I don't think there could possibly be any easier way to do it.
rocco52 is offline   Reply With Quote
Old 08-21-2017, 08:31 PM   #18
True!
but takes up more room.
Old 08-21-2017, 11:09 PM   #19
zapper's Avatar
Thanks , all good suggestions. Decided to buy from Amazon, couldn't find in local stores. Thread about battery maintenance got me thinking about time to top off batteries with distilled water.
Old 08-22-2017, 08:20 AM   #20
Zil
Curtis Wright
Eyren Haven , South Jersey
I had a medical intravenous drip set up for a cat. Cat was comfortable to the end. I have the tube and pinch valve. A gallon jug of distilled water above the bank. The tube into the water, draw a siphon, and fill each of 18 cells as needed. I can easily see what is going on in each cell, therefore No mess, little fuss. The gallon jug needs a storage space, but the pinch valve and tube can go most anywhere. There I have published my secret to a dry battery box.
Zil is offline   Reply With Quote
Help! Need help finding inspector in FL. metersixty Buyer Guidelines 1 01-04-2017 06:17 AM
Need help finding new hot water heater to fit 1968 tradewinds rothway Water Heaters, Filters & Pumps 2 07-18-2015 09:12 PM
'98 30' LY MH... Water comes out filler vent when pump is turned on. Help! SNielsen Land Yacht/Legacy Motorhomes 3 07-19-2010 08:04 PM
Plumbing/water filler Rog0525 Fresh Water Systems 10 08-01-2004 10:00 PM
Where can I find a Minuet water filler hatch? Janets Husband Fresh Water Systems 9 05-12-2004 09:45 AM
