Old 07-21-2005, 09:36 PM   #1
JMGAZ's Avatar
Need fuses...
Can someone give me the specs on the 2 glass fuses that are used in the battery compartment on a '67?
I just picked the coach up and it did not come with an owners manual. The fuses that are in appear to be extremely old and I can not see any product info on them.
JMGAZ is offline   Reply With Quote
Old 07-21-2005, 10:50 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Try Anglers Marine or West Marine or some other marine supply store. Take the old fuses with you.
Bill
Just my personal opinion
Old 07-22-2005, 08:40 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Try here
http://www.campingworld.com/browse/s...=4364&src=SRQB
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 07-22-2005, 08:58 AM   #4
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Those fuses for the '67 are the larger glass fuses. I had a hard time finding them as well, you can find the right amps but getting the size correct was hard. You mightbe better off just replace that fuse block with one that has more current fuse options. That was on my list before I sold my '67 Tradewind.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 07-22-2005, 01:57 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
If they are the big fat glass 50 amp fuses that fit on the pos. and neg side just like my '77 Excella then they can be hard to find. I found mine at Cullum & Maxey RV in Nashville, TN.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-22-2005, 05:24 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
If they are very large glass fuses, they are probably 50 amp rated. The smaller ones are automotive type, IIRC, they come in AGC and SFE type. They difference in the two is the length.
If only I'd thought to bring... 4521red On The Road... 177 05-07-2018 06:16 AM
replacing glass fuses with blades maznblu Electrical - Systems, Generators, Batteries & Solar 4 08-05-2003 11:34 PM
Fuse size? working Electrical - Systems, Generators, Batteries & Solar 5 05-08-2003 10:11 PM
12 volt fuses jim clydesdale Electrical - Systems, Generators, Batteries & Solar 2 03-18-2003 05:47 PM
Electrical problems... DbackFan Electrical - Systems, Generators, Batteries & Solar 9 02-13-2003 10:44 PM
