Old 10-29-2008, 04:46 PM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Need electrical system expert advice
I’ve got some strange electrical issues that I’m hoping you electrical experts can help me with- or at least give me some ideas that I can raise with J/C…
We’re talking about a new 2008, that I took possession of in late 2007.
Dead, and quickly drained batteries (while boondocking) had me thinking there was a problem right off - but I couldn’t be sure, since the coach was being used 90% of the time plugged into 30A shore power…. and it seemed to perform OK on shore power… (except when it melted the head of the power cable at a campground utility box- I chalked that up to a bad electrical service)
So after freshly charged batteries had gone dead, while sitting in my driveway overnight- I decided to install a Trimetric 2020, and attempt to identify if, and on what circuit, there might be a short… and also get a better idea of what was happening charge-wise.
Got around to installing the 2020, along with a 100A shunt. The distribution bar next to the charger/converter had only one ~4AWG black wire… so I tapped that for the shunt… and on the opposite distribution bar, I connected the Trimetrics fused positive wire to the stud that connected to the coverters + hookup (Bogart tech support said that should be OK, although they recommend going directly to the battery stud)
Readings on the 2020 look respectable:
-.05 kill switch ‘off’
-1.60 water pump cycling
-4.80 furnace fan blowing
-11.70 all interior lights
At the time I installed the 2020- The trailer was winterized, and in storage- I didn’t have any shore power… plugged the chevy burb in at the umbilical cord, and idled the engine…
This is where it gets interesting
The 2020 showed -.09A and 12.9V no charge.
Checked the burbs 7-way, showed ~14V (the P3 brake controller also showed ~14.00V)
Let idle for about five minutes.. no change in Trimetric reading.
Then- while I’m scratching my head, staring at the Trimetric, my helper ‘accidentally’ hits the brakes in the burb, activating the actibrake hydraulic pump in the trailer—suddenly the amp readout jumps from -.09 to 1.12 and shows charge
After a couple of minutes, the amps drop to -.19 (we’re still hooked up, with burb idling)
We repeated this sequence (hitting brakes, showing charge… then a few minutes later showing a drain) several times
Sorry for the lengthy post.. any help would be greatly appreciated...
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 10-29-2008, 05:46 PM   #2
Images: 59
Joe,
Intriguing. Are you using the Suburban battery to power the Actibrake, or did you wire it to the trailer battery?
Old 10-29-2008, 05:55 PM   #3
Dearborn , Michigan
Images: 21
Originally Posted by markdoane View Post
Joe,
hey mark,
it's gotta be wired to the trailer batts... when I bled the brakes (on the a/s), I could cycle the pump by pulling the breakaway switch- and that was disconnected from the burb
Old 10-29-2008, 06:10 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
My conjecture
Your dead batteries could be the result of bad batteries or a big parasitic load you have not yet found. Disconnect the batteries and see if they discharge on their own.
Your converter might have stepped up it's charging activity when your assistant hit the brakes because the increase in current caused by every single brake light coming on AND the brake controller powering the brakes caused a momentary voltage drop in the charge line which fooled the converter into thinking it needed to come on to combat a power hog.
Even though the surge was brief, the converter might have been programmed to stay on the job to make sure everything was okay.
Tom
Old 10-29-2008, 06:22 PM   #5
Dearborn , Michigan
Images: 21
Tom
Tom,
but wouldn't any parasitic draw show on the 2020?
would that kind of behavior, by the converter, indicate a bad unit?
Joe
Old 10-29-2008, 06:24 PM   #6
Images: 59
Originally Posted by finalcutjoe View Post
hey mark,
It has to be wired to the trailer battery for the breakaway function to work, but the instruction sheet says the primary power connection is to the tow vehicle.
Is it possible that the relay on the actibrake is causing power from the tow vehicle to try to charge the battery, when the brakes are activated?
Old 10-29-2008, 06:31 PM   #7
Dearborn , Michigan
Images: 21
like if the brake control wire was shorted with the power wire in the tow vehicle harness or umbilical?
Old 10-29-2008, 06:58 PM   #8
Images: 59
No, I don't think it would be a short.
I think the Actibrake has two sources of power to the pump. It may have a relay that takes power from the tow vehicle if the umbilical is connected, and if the umbilical is disconnected is takes power from the trailer battery.
I'm kinda shooting in the dark here. I'm guessing the main power source is the tow vehicle because it uses a #12 wire, and the back-up breakaway power is only a #16 wire.
I'm sure it's a lot more complex than I imagine, but if the blue wire tells the pump to turn on, it might close the power relay and send 14 volts from the tow vehicle to the trailer battery.
I also think Tom is on the right track thinking that the power flow from the tow vehicle needs to exceed some threshold value before the power comes on.
Old 10-29-2008, 08:41 PM   #9
1989 34' Limited
toronto , ontario
http://www.airforums.com/forums/f439...g-30369-2.html
this post could answer be the answer to your problem, caused from the electric to hydrolic pump, lots of reading.
letsgo123 is offline   Reply With Quote
Old 10-29-2008, 09:02 PM   #10
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
Perhaps another datapoint: put a meter across your positive bus and negative bus, and compare with the trimetric reading. Repeat with umbilical connected.
Do the readings match with the trimetric?
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-29-2008, 09:36 PM   #11
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Don't know about the later models but when the breakaway is pulled power to the brakes is from the trailer battery and when the brakes are applied power comes from the TV brake controller.
I suspect you need to verify the battery (charge line) from the TV is connected to pin #4 of the 7 way connector (black 10 gage wire) and the #4 pin on the Airstream side goes to the battery this sounds like a miss wiring on one end.
Garry
Old 10-29-2008, 10:31 PM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
possible?
Hi, sounds like another one of the wonderful G.M. tow vehicles connected to an Airstream with disc brakes sindrome. Check for the dummy fuse [instead of a real fuse] that G.M. uses in their fuse panel that is needed for the charge wire in your seven pin connector. Seems that this has become a common problem with this set up.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-30-2008, 05:21 AM   #13
Dearborn , Michigan
Images: 21
whew... just read
looks like after much aggravation, it turns out to be a missing AUX/POWER underhood fuse?
the fuse is definitely in, and I'm reading +14V at the suburbans 7-way...
</electrically challenged newbie thinking out-load> it's simply a bad actibrake controller... 'soaking' up any charge from the suburban?
Old 10-30-2008, 05:27 AM   #14
Dearborn , Michigan
Images: 21
Garry
what position is 4 on the a/s umbilical?
my suburban 7-way is giving me +14v at the '2' and '7' o'clock positions... (alignment notch at '12')
confusion with my electrical system funkill Batteries, Univolts, Converters & Inverters 15 09-20-2008 07:16 PM
Newbie needs help with electrical system jacqueg Batteries, Univolts, Converters & Inverters 7 11-29-2007 04:00 PM
electrical system crowldawg Batteries, Univolts, Converters & Inverters 6 09-27-2007 09:36 AM
electrical expert needed Frank's Trailer Works Batteries, Univolts, Converters & Inverters 8 08-17-2007 10:59 AM
electrical system diagram duckrunner Electrical - Systems, Generators, Batteries & Solar 3 10-22-2003 07:53 PM
