Old 05-13-2013, 01:43 PM   #1
1989 35' Land Yacht
Reno , Nevada
need alternator 1989 Land Yacht Motorhome
The common alternators at auto parts stores are not setup for the bracket attachment. any recomendations?
normabc is offline   Reply With Quote
Old 05-13-2013, 02:03 PM   #2
1968 20' Globetrotter
1993 32' Excella
Jax , Florida
Go to an alternator repair shop, they will know where to get one. They may have one to build or in stock. ... or modify the bracket to fit a common alternator.
luvoldstuff is offline   Reply With Quote
Old 05-13-2013, 02:30 PM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
When I needed an alternator for my boat(diesel) I just took it into NAPA and said I need one just like it, he went into the back and came out with an exact match. Did ask as he was writing ticket what vehicle was I putting it on If I would have said a boat he probably wouldn't of had it in stock.
Old 05-13-2013, 02:30 PM   #4
1989 35' Land Yacht
Reno , Nevada
Thanks for the reply but I do not have the original alternator. I have purchased 3 from 3 different parts stores and the housings are too large
Old 05-13-2013, 05:24 PM   #5
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Not quite sure what you mean by a 1989 Land Yacht moho. My 1989 is a 345. Anyway, I have a chevy 454 engine in mine. I put a new alternator in back in March 2011. It was purchased at AutoZone. It is a Valuecraft brand rebuilt unit. Part # 1352-5-11. I did have to remove the serpentine pulley from the old unit to put on the new one. You'll probably have to buy a pulley too. Hope this helps you.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 05-13-2013, 07:47 PM   #6
1989 35' Land Yacht
Reno , Nevada
need alternator 1989 Landyacht motorhome
Thanks for the info this what I hoped someone would have a part number and maybe it will work on my unit
Old 07-22-2013, 11:31 PM   #7
1990 36' Land Yacht
Slidell , Louisiana
I know I'm late to the party but my alt just went out
Thanks for the part number but I got a question. What size alt is thay as in amps and how has it worked for you? My 1990 AS LY 454 doesn't have a sepertine belt it has 3 belts
I would love to convert it to a single serpetine belt
Is this doable
I know I would need to change all pulleys and add a tensioner. I know the 454ss model chevy pu has a sinlge belt so I would think those parts would fit. I'm concerned about the alignment of the pullies
Would be gratefull for any info
ryjamsan is offline   Reply With Quote
Old 07-24-2013, 06:05 AM   #8
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Is this doable
Having had belt problems in past motors, pulleys are so specific and alignment so critical I would say no the average backyard mechanic can't do it. There are some here who are super first class mechanics that could answer yes. You can even screw the system up by having the wrong brand belt as some have changed the original belt width sizes.
Old 07-24-2013, 07:52 AM   #9
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
Wrong brand ? brand doesn't matter as long as the dimensions are correct. Some brands will last longer than others but brand won't tear anything up.
The conversion should be doable by most anyone with mechanic skills. Check with some of the aftermarket hot rod companies or do a search for accessory serpintine belt conversions for 454. kwickperformance.com has a conversion kit. That was the first one to come up doing a search for it.There should be many more like summit racing. Just do a search and you should get your answer.
panheaddale is offline   Reply With Quote
Old 07-24-2013, 08:01 AM   #10
1964 26' Overlander
1968 30' Sovereign
Try different year model for the alt. Check the amp rating on the alt. larger amp rated may have a different housing. If their happens to be a parts store near you that is still privatly owned go there you will get someone that is a parts guy and not just a computer reader. If not go to Napa they are still a parts store unlike autozone,advance,o'reileys. If the computer doesn't tell them the part number they usually look at you stupid and tell you they don't have it or they don't make it. You can also check with an alt. rebuild shop they are going to be able to give you more info than anywhere else.
